Trunk Door motor malfunction
Argh!
Yesterday, my trunk door refused to close several times until I had to play wiht the unlock button and the trunk release button in the dash before I could close it. Today I had to grab some stuff out of my trunk and put other stuff in the trunk, but the trunk refused to open when I placed my hand underneath the trunk. I tried so many times to get it to open and I couldnt. The dealer was kindly enough to look at it quickly on my way home and found out that the motor was malfunctioned and they had to order a part. There's a TSB out there for this and I am wondering if anyone else had this problem. To my embarrassment, I have to take out the key from the key fob now and open the trunk manually and when I close it, I have to close it hard or push it down to lock since hte motor is not working. This is my second problem since the dash rattle was resolved. Overall, I am a bit upset but hey thats life.
calebNS (11-08-20)
My trunk latch also recently begun acting peculiar. TSB BO0001-06 describes the problem with the trunk lid motor and its replacement. It applies to the GS300, GS300AWD, and GS430 VIN numbers below these VIN numbers:
GS300: JTHBH96S565026215
GS300AWD: JTHCH96S660013636
GS430: JTHBN96S465010757
My GS's VIN falls below the production change number so I'll be again making a trip to the dealer.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
This trunk release problem must still be unresolved. My 07 GS350 just started to refuse to have its trunk opened either by the dash board control or by the trunk switch or by the remote (I have the keyless system). I was able to open it by sliding a long broom stick through the rear seat access door and then pushing down on the inside emergency release lever. As a temporary (I hope) fix I tied string to the lever such that it exits out of the bottom of the trunk hood when its closed. By pulling on the string I can open the trunk. Great solution for a 50K car until I can see the dealer!
Ray
Ray
Ray
Ray
As for the original post. I recently have had the same issues with my trunk pull down mechanism. Sometimes it actually works, other times it will want to reopen the trunk after i close it and pulls it down. Quite annoying. I found that holding the trunk down after it latches for a few seconds was the only way to get it to close and not reopen. There is no sort of obstruction anywhere that should cause it to do this.
calebNS (11-08-20)
Yup, when I read that, I was thinking the same thing! Then, looking at his/her sig, I realized why. Some people are just snotty!
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
I am not snotty, I am actually a very humble gentlemen. My Lexus is actually the favorite car out of the bunch. Its working like a charm now since the replacement of the trunk door motor. Also, if the key did not have to be removed from the key fob and looks like that of the RX key, it would be much more easier to open. Now it closes more easily and now I try to close it more softely. Overall, the car is 5 out of 5 stars for me. The GS is one of the best Lexus I have ever owned.
calebNS (11-08-20)
I didn't find your post the least bit snotty or whiny. After paying $50K for a Lexus, I too could be embarrassed when a simple trunk release didn't work. And we could debate the usefulness of the automatic closing mechanism that has caused some of us trouble, but that's another topic.
Rexus300, thanks for your post on this topic. Your comment led me to finding the TSB and yesterday my Lexus dealer replaced the motor.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Trunk opens with pull lever under dash and with key in lock on trunk.
Have tried "valet" button in and out with no luck.
Any further ideas?
Any further ideas?
