Successful DVD-Audio Disc with ML system!!!
You guys lost me in the technical mumbo jumbo but I tried making a audio DVD with Audio DVD Creator and have to say that the sound quality is substantially worse than a MP3 burned onto a CD-R. At louder volumes, there was no distortion with a MP3 but there was definite distortion with the Audio DVD. IMO, there is no advantage to any of this because the problem with the ML system has poor imaging with 2ch audio so nothing can be done to improve the situation even with lossless, high quality this and that or even the original CD track. Do you guys know if it's possible to create a 4.7gb DVD full of MP3 files?
lot's of info here ...
i'm really not following you guys . i tried making a dvd audio mp3 disc by Nero but it didn't work on the ML .
as drex said there is no diffrence in quality between burning mp3 CDs an DVD's .? if true what's the point of making dvd-a's?
or is it the software that i use?if true what's the best audio dvd burning software that i can use to notice the dvd-a quality?.
There is no point in making DVD-A regarding sound quality unless the source is better than 48/16 PCM. Although one can burn either DVD-A or DVD-V with 2-ch 48/16 and that would increase playing time x7 compared to regular CDs--so that's a good reason.
no i've got a 07 IS that plays mp3's.
so this "48/16 PCM" thingie i will find at the burning software's settings before burning?
and when you say better you mean the numbers should be lower or higher?
i know i am a newbie in these things but i am trying at least.
burning CD's is all that i know.
If you are sourcing your music from MP3 files, or you want to use MP3 so you can carry as much music as possible on a disc, then by all means leave the files in MP3 format, and forget about putting them on DVD-A discs as PCM. You'll have more playing time from an MP3 coded CD than a PCM DVD.
As for the troubles with putting MP3s onto a DVD disc, I can offer no other ideas other than to check the owner's manual to see exactly what types of discs the player can use. If it says MP3 CD and does not say MP3 DVD, it might not be an oversight.
![Smile](https://www.clublexus.com/forums/images/icons/icon7.gif)
Another way to burn music disks. I have the Mark Levinson (ML) audio system and have experimented with burning music to both DVDs and CDs. Even though you can get 600 plus songs on a single DVD I personally do not like music DVDs. This is because they are recorded as if they were a Video File (a movie) and I could not see the song titles as they played plus I had no other control over them. It may be somewhere but I couldn't even get DVD recorded songs to play in a random sequence like you can with CDs. The only consistant thing I was able to do is get the DVD to AUTO START so the music starts and plays without fiddling around trying to get the DVD to start.
I now burn my music on CDs in the MP3 format. Depending on the MP3 file sizes it appears that you can get about 250 songs per CD. I have already tested a CD with 204 songs on it and it plays perfectly. That means with a six-disk CD changer I can have 1,500 songs in my ML Audio system. You can easily choose to play the songs sequentially, random, or repeat even when driving. When the car is moving the song title that is playing is shown on the screen.
On the other hand, when the car is NOT moving I can view and scroll through the entire list of song titles on the CD because you can access the FOLDERS and FILES menu, which is grayed out when the car is moving. See last paragraph for how to do this while driving.
THIS IS MY EXPERIENCE: I could not get Windows Media Player 11 to work with the Lexus Audio system because it wants to use the .M3U playback format. I found buried at the end of a sentence somewhere in the Lexus manual that .M3U playback will NOT work. NOTE: the playback format for songs is different from the MP3 recording format for the songs.
I used Sonic System’s Roxio Easy Media Creator 9 to burn a music CD with 204 songs on it and it both plays and shows each song's title as it plays even when driving.
Here's how I did it. Start Roxio, click on AUDIO, choose MUSIC DISK CREATOR, choose MP3/WMA disk, click FILE (upper left), click IMPORT AUDIO in the drop down menu, in the left pane of the two panes that just appeared click on My Computer to get to your C: drive and find you music files (songs) you want to burn, choose the songs you want to burn by clicking on them (they change color), click on ADD (middle right of screen).
If you want to edit any song's title, before burning the CD, click on that specific song and then click on Edit Audio Tags.
Then choose PROJECT SETTINGS. Here you name your disk, choose convert all to: MP3 (good quality), uncheck .M3U and leave only .PLS and .WPL playback formats checked, for file use Joliet and press okay to return to the previous screen.
Next, look at bottom left of the screen to make you have an 80 Min (703 MB) CD in the CD burner. Now click on BURN (right middle of screen). You probably should not use a rewritable CD-R.
This worked very well for me!
Furthermore, you may be interested in this detailed HOW TO description on: Enabling access to the Music Folders, Phone Dialing, Calendar and Maintenance Menus while Driving the Lexus ES350.
https://www.clublexus.com/forums/sho...d.php?t=276775
While DVD-A discs are able to deliver high resolution PCM, 96/24 and such, it cannot do anything to increase the sound quality of any source. It can perfectly preserve the quality of the source, but no more. So if your source is MP3, which is probably made from a CD, the best quality will already be preserved with DVD-A files at 44.1/16. The same is true if you make DVD-A discs directly from CDs, and this will then give you the maximum playing time from the DVD-A discs. If you upsample CDs or MP3s to 96/24, you’re cutting down the playing time to less than 1/3d, but gaining zero in fidelity.
In addition, the ML system can play back only 2 channels of PCM from DVD-A. So don’t bother making any source files with more than 2 channels. If you have a source of 5.1 programming, then you’re better off making a 5.1 Dolby Digital DVD, or make a DTS CD. Both of those will play perfectly and preserve the discrete 5.1 quality.
1. What audio quality advantage, if ANY, is there for making a DVD-A from a CD?
2. Will a purchased DVD-A have been audio quality than a CD?
3. Where can one buy DVD-As on the internet?
Bottom line: Are DVD-As noticably better than CDs on ML, and, if so, where can I buy the DVD-As?
Bottom line: Are DVD-As noticably better than CDs on ML?
Classical recordings are usually the least compressed, so they sound quite good. It's due to this that it's more difficult to enjoy classical music (or movie soundtracks) in cars, since they loudness ebbs and flows over a greater range. If you are asking if classical music benefits from DVD-A, surely it does. Can you really hear that difference in a car compared to a CD? Rather less than one can appreciate from the same comparison in a home playback system, I'd say.
If fidelity is really your goal, try to avoid MP3s and get the original CD source. Or a lossless file made from the CD.
People help me out please. I listen almost exclusively to classical music and would like to get the best sound possible from my ML in my new 2008 GS350.
1. Should I buy classical music Dolby Digial DVDs and play them? If so, how do I skip tracks when the car is moving (assuming I do no mods on my leased car).
2. Would DVD-A discs be almost as good? If so, where would I find these strange beasts that I've barely heard of before?
3. Just play normal (commerical) CDs?
4. Would most people be able to tell the difference between 1, 2 and 3?
I'd love lots of advice please.
I USE -
ImgBurn for burning all DVD-A images.
DigiOnAudio2 - for creating DVD-Audio with Vinyl Rips
96/24 sounds awesome
i cant wait to try this...only thing holding me back from not using my old ipod that has a messed up center key....ipod wasnt nearly as great as cd
