Force Eject Hybrid Nav DVD
Old 04-23-07, 12:22 PM
oscar667
oscar667's Avatar
Unhappy Force Eject Hybrid Nav DVD
I accidentally left a bad hybrid DVD in the drive while pulling the navigation system fuse. Now the system does not boot and displays an error message specifying to consult the dealer. The menu for ejecting the DVD is no longer available. Does anyone know how force eject the DVD from the drive? Your help is much appreciated!
Old 04-23-07, 01:31 PM
phattbam
phattbam's Avatar
I have no idea how to eject it. but I was wondering which model Lexus is this from? Do you have the ML Nav system and which fuse # from which panel/box is it? I'm still trying to get the hybrid dvd in without disconnecting the battery.
Old 04-23-07, 01:51 PM
2007GS350
2007GS350's Avatar
I think you press the upper right corner and then lower right corner of the navi screen to get it to eject.
Old 04-23-07, 03:18 PM
oscar667
oscar667's Avatar
2007GS350: Thank you much! That worked. I got my map back.
phattbam: It is a non-ML Nav. Fuse number 3 (labeled TV) of the driver's side fuse panel.
Old 04-24-07, 09:10 AM
phattbam
phattbam's Avatar
that should get the Hybrid disc to read?? awesome I gotta try it out later.
EDIT: forgot to ask you what model Lexus you have. as some models have different fuses in different areas.
Old 04-24-07, 12:32 PM
phattbam
phattbam's Avatar
I tried to remove the fuse and I"m getting an error message about not being able to read the disc...
Old 08-18-07, 07:44 PM
rotaryrox
rotaryrox's Avatar
So.. i just turn the car on and press upper right than lower right corner and it will pop the navi disk out ? for an 07 gs 350?
Old 08-18-07, 08:58 PM
phattbam
phattbam's Avatar
it's actually a different firmware I believe now. you would need to create a hybrid DVD for that "trick" to work. I'm still trying to get mine to work
Old 08-19-07, 02:27 AM
Eiso
Eiso's Avatar
same here...tried using my external Sony DVD DL burner with Verbatim DVD DL...doesnt work!
Old 06-05-09, 11:13 PM
ES3
ES3's Avatar
Actually just the upper right corner for my '08 IS-F.
Any of you get the hybrid disc to work? I get the "can not find program, please consult dealer" message when I pull the fuse and inject the hybrid map dvd.
Old 06-06-09, 03:33 AM
Lexus GS3
Trouble Maker
Lexus GS3's Avatar
Did you get the hybrid disc to work? If so what data software are you using 7.1 or 8.1?
Old 06-06-09, 05:28 AM
ecount00
ecount00's Avatar
fyi I was able to get a dvd 6 hybrid to work easily a couple of years ago but was never able to get a 7 or 8 hybrid to work. the type of blank dvd, burner and software is important but not the issue in my case. those variables are easy to eliminate by burning just a straight legit backup copy of the original. if the backup works, all the equipment etc is fine.
some members claim to have been successful with a 7 hybrid. many others could not get it to work. there are many many threads on that. assuming the mixed results, there are so many variables it's hard to sort out. i have gen 4 system, others gen 5, various versions of firmware that have been loaded in various cars before a hybrid was tried etc. good luck
sartask
04-21-11 06:13 PM
RhoXS
02-24-11 08:55 AM
scalum1994
04-08-09 06:18 PM
Quick Reply: Force Eject Hybrid Nav DVD
