Nitrogen Tires
Old 05-02-07, 06:40 AM
NJSID
NJSID's Avatar
Default Nitrogen Tires
Has anyone received an offer from their dealer for the nitrogen tire inflation system? Got one from my dealer for $74.00 whereas they say it improves fuel economy, braking, handling, temperature and wear & tear! I'm not aware of the benefits of nitrogen but I doubt if it would save me $74.00 worth of gas a year but I could be wrong! I have run-flats if that matters.
Old 05-02-07, 07:15 AM
twister
twister's Avatar
There are definitely benefits in using nitro, but than you will be stuck with your dealership or a local priceclub place (either BJ or Cosco where they offer it) to inflate your tires. You can't mix'n'match air and nitro, always have to be consistent. I think just by switching out of those horrible rf, you can get a lot of those benefits I'm just waiting for those to wear off until I will go to normal tires. I already got 5k and probably will be looking to switch at around 15k.
Old 05-02-07, 07:28 AM
Lexmex
Super Moderator
Lexmex's Avatar
That's way too expensive. It cost only $25 USD equivalent for my RX300 down here, and Costco down here was offering it for only $18 USD (includes all 4 tires). I know Costco in the states offers this, too.
Do a search on CL for nitrogen...the benefits are there (I know), but that price is way too high at $74.
Old 05-02-07, 07:35 AM
Seize
Loves Snickerdoodles!
Seize's Avatar
Here's a thread with quite a bit of info on putting nitrogen in your tires
https://www.clublexus.com/forums/sho...light=nitrogen
Old 05-02-07, 07:49 AM
twister
twister's Avatar
Just curious, are those $18, $25, $74 supposed to be one time fee or do you have to pay it yearly?
Old 05-02-07, 08:35 AM
Jace7
Jace7's Avatar
PAY FOR NITROGEN FROM A DEALER? WTH?
Never.
If they started charging me for what I have always been able to get free at the dealership, I'd switch to air.
Yes there are more benifits, more stable, so in winter, your TPS won't go on/off on/off. The lbs reaction is about 1/2 lb for ever 70 degrees. whereas air is about 2 lbs.
AIrplanes can only use nitrogen for the expansion contraction at -200 in the air.
It's more stable.
And yes, there is supposed to be better wear and better control, and blah blah...
Not worth the 75 dollars though. But it is better...
Old 05-02-07, 09:05 AM
NJSID
NJSID's Avatar
Nitrogen sounds good but I won't pay my dealer $75.00 for something I can get at costco for $20.00 as previously mentioned. You would think a LEXUS dealer would or should do it for free!
Old 05-02-07, 09:08 AM
Jace7
Jace7's Avatar
mine does, it's standard, and YES THEY SHOULD> all should.
Old 05-02-07, 02:59 PM
ILOVEGIRLS
ILOVEGIRLS's Avatar
can you use nitrogen in aftermarket rims?
Old 05-02-07, 03:58 PM
DavidsGX
DavidsGX's Avatar
My Acura dealer offered $39.99 and feel no different at all in milage or driving confort. I don't plan to get it when my Lexus offers the same thing!
Old 05-02-07, 05:35 PM
Lexmex
Super Moderator
Lexmex's Avatar
That's how much the nitrogen costs to fill up once. I think Costco's membership is like $30 USD a year.
Old 05-03-07, 07:08 AM
Jace7
Jace7's Avatar
you can use nitrogen in anything that would normally take air.
so yes, the wheels do not matter. nitro away
Old 05-03-07, 09:41 AM
twister
twister's Avatar
Hey, maybe they charge $74 for a set of those 4 green valve caps they have to replace when nitrogen is used in your tires?
Old 05-03-07, 09:54 AM
Jace7
Jace7's Avatar
mine do look nice..... maybe that's it.
Old 05-03-07, 10:54 AM
Lexmex
Super Moderator
Lexmex's Avatar
It make a bigger difference up here with the lack of oxygen in Mexico City. The tires get very hot, and although racers want their tires sticky for traction, they don't want it to a point where the psi jumps around in the tires when they are racing.
Quick Reply: Nitrogen Tires
