Beware!!! Uneven Wear on the Rotors
+1, something doesn't sound right. Does the LSD help or are you sideways all over the place with that much power?
The Quaife is a torque-biasing-diff (no decel lock-up). It helps on turn 7 at Road Atlanta to keep the inside wheel from spinning on track-out, and also for Autocross. Helped take about a second off my lap time. Have you ever tracked your Carrera? You've got some of the best tracks in the country where you are!
And to keep this on-topic.....throttle-lift oversteer is not an issue with our front engined, rear drive GS's.
i have like 35k. you think maybe it could be break pads because i know you have to a sacrifice something for having 0 brake dust, you think it gets to hot? when i had them checked the last time it still had plenty of pad left hardly any wear. hell i have yet to turn anything on my Z and i drive that baby good.
The chassis handles the power very well...hence the suspension mods. The rear weight bias on 911's is a benefit as long as you can manage to keep the power on throughout turns...even those you take a bit too fast (the trick is to balance understeer with a "bit" of throttle lift to maintain the line). Just don't overcook it and lift off the accelerator abruptly. You'll spin like a top! That's the reason so many 930's got totaled in the late 80's. Full boost would hit unexpectedly (turbo-lag) around a curve and the instinctive "lift" would send them flying into the trees. Later 911's like yours are a bit more civilized (PASM) but you still can't completely override the laws of physics. I'm guessing you've got a few stories of your own....we all do.
