Does the VAIS SLi unit press I agree for you
Not sure if you performed the procedure or not. It is on Page 9:
>>Activate / Deactivate “I Agree” Automatic Bypass Function
1) Put your device in Simple Mode by rapidly pressing the [SCAN] button 8 times (MUST BE DONE within 1-2 seconds).
2) Push DISC REPEAT button to hear a long beep to toggle the “I Agree” Automatic Bypass Function ON and OFF. (For
vehicles not equipped with DISC REPEAT as a physical button, push and hold the REPEAT button until you hear a
long beep to toggle the “I Agree” Automatic Bypass Function ON and OFF. <<
It works in my 2006, FWIW.
Do you need to have the IPOD plugged in when you do this because I did it without the IPOD and it does not work.
I have the SLI IPOD which was installed in July or so of last year.
I am also assuming you need to be on the SLI IPOD screen and are hitting the scan button that is visible on the screen as well...when I do it, the 7th time I press it, it beeps which seemed odd
The unit shows it is in simple mode but when I hit the dsc repeat button on the screen I never get the long beep.. I have an 06 gs 430.
Thanks again.
Thanks again.
Thanks again.
Called VaisTech and here is the deal:
The software for the I Agree button came out in November of 06.
I bought my Vais in the summer of 06
soooooo
I have ordered the update ($ 50.00) and will have to reinstall the Vais Software to the newest version.
Then it should work.
N
soooooo
N
Since I did not install it myself, I would have no clue on how to pull the unit out, nor do I know where it is installed at in the car...
Im not sure I even want to go there...!
Yes...or you can pay to get the adapter and download the software from a laptop through the ipod cord yourself...
How easy is it to get to the box if it is below your radio where my installer said it is at?
N
N
