Tire Pressure Sensors
I know there has been plenty of post on TPS....However, i've been seeing different people still having issues with the lights coming on.
I have some 20' Lowenhart's that I have been waiting to put on and my question is:
When I do put them on, should i purchase new sensors or switch over from my stock rims? Different Lexus dealers are telling me different things.
Do i have to pay Lexus to reprogram the sensors to my car or can I simply reset it myself under the drivers side?
Will the light still come on once sensors are put on and reprogrammed? and is something i just have to deal with repeatedly?
put them in your spare and call it a day when you put on your new wheels...
in my opinion...if you're running 20's the TPS probably wont save you by the time you can tend to the issue if you have a leak for example...just one of the risk with large rims...again...my opinion only.
I have two sets just to make it easier when switching between different sets of tires....but that was before I knew about what HKN was mentioning. Once I knew about what HKN said, I just put the TPMS sensors in the trunk and then I didn't have to worry about installing them on my aftermarket tires....most people just want to eliminate that dashboard light anyways.
Wait a minute. You put the sensors in the trunk (not in an inflated tire) and you don't get a dashboard light?
I would transfer the stock TPMS sensor onto your aftermarket wheels. They'll help detect slow leaks or minor punctures and it'll help especially if you're on three-piece wheels because a lot of three piece wheels tend to spring slow leaks after some time.
i had an issue with my tire sensors after i put my 22's back on my gs. the rim shop took the sensors off my stocks and put them on the 22's and i had no problems at all. after a while i put my stocks back on and i got a check system light that came on. i eventually put my 22's back on and the light stayed on which was extremely annoying. i read on another thread that under neath the driver side steering wheel, there is a little button. have your car on in park and press and hold this button until you see a message like 'tire pressure initialized' or something like that. then you turn your car off and turn it back on. after a couple of minutes my 'check system' light turned off.
What do you mean when you say throw it in the trunk? Do you mean just leaving all 4 TPS hanging around inside the trunk or installing to my spare tire?
If I do just leave them inside the trunk without installing it into my aftermarket rims, would this eliminate the light issues?
I had to read the manual to fix my tire pressure light today. turn your car on, press and hold the TPMS button. the light will flash slowly 3x, then it well display a message. you're good to go after that.
Orginally, I was going to install my 2nd set of sensors into my aftermarket wheels but since the wheels are not made for TPMS, it meant the sensors would be mounted behind the face of the rims, therefore making the adjustment of tire pressure nearly impossible. The other choice would be to install TPMS inside the aftermarket wheels by utilizing a tire strap. The problem is that I've had a friend who did this to his car and it came loose after a hard bump in the road.....if that happens, then you'd be really screwed since the TPMS would almost certainly break as well as having to dismount/remount the tires again.
Hope this clarifies things.....
Curtis
Thanks for all assistance...
So basically, if I buy a new set of TPS sensors, I can have Lexus dealer program them into the secondary settings and just leave the sensors in my trunk or my spare? Doing this will disable my dash light?
Here is what I did, I bought a set of HRR MR2 in Chrome, 19 inch. I then got a second set of TPS from Sewell Lexus, they had the best price. All after market wheel manufactures will say that their wheels are TPS compatable, the way the LEXUS TPS is made, it fits on the inside lip of the rim. My after market wheels didn't have this lip. When we mounted them I would get air down after an hour at 80mph, very disturbing. I had my tire guy remount the TPS with engine sealant to keep the threads from leaking air, which they do even on the factory wheels unless you use some sealant. The TPS are mounted with a hard plastic collar, kinda of a poor design. After the sealant no problems. The lexus dealer charged me $35 to initialize. He them showed me the button on the passenger side underneath the glove box to hit when I put my stock wheels and tires on for the winter.
I like to have things work so the light on all the time would drive me crazy.
Lexus will charge you approximately $220 to do everything (labor only).
Curtis
