Non Ml System Use To Play Dvd Through Nav Screen
Old 06-03-07, 05:52 PM
hiendo85
hiendo85's Avatar
Default Non Ml System Use To Play Dvd Through Nav Screen
IF ANONE IS INTERESTED IN DOING THIS MOD...LET ME KNOW..I GOT IT DONE TODAY, TOOK ME 2 DAYS TO FIGURE OUT THIS ******t.... FINALLY, BUT GOT EVRYTHIN DONE AND WORK PERFECTLY... ALL YOU NEED IS TO CUT FOUR WIRE AND SOME SWITCHES.....SAVE ME 3,000 FOR ML SYSTEM.. I SPENT $150 FOR EVRYTHIN TO PLAY DVD IN MY NON ML SYSTEMM.... LOVING MY CAR.. OH AND I CAN WATCH WHILE IN MOTION TOOOO....
Old 06-03-07, 11:50 PM
thomastp
thomastp's Avatar
Default would love to know how....
i have an 06 gs non mark lev, how did you make it play dvd's? please post. tanks in advance
Old 06-04-07, 01:35 PM
bozer
bozer's Avatar
Wait so you're able to play DVD movies through the screen without a ML system? Because the thought of driving around and watching **** is just too tempting to me.
How is it done? Where can I get it done?
Old 06-04-07, 02:32 PM
anwar1337
anwar1337's Avatar
haha and have the sub cranked all the way up so you can hear that **** all the way down the streeeeet LOL
Old 06-04-07, 04:18 PM
Yang1815
Yang1815's Avatar
down the street?!
you mean across town right???
Old 06-04-07, 06:24 PM
brownz
brownz's Avatar
http://www.nav-tv.com/
Old 06-04-07, 06:44 PM
hitechgs3t
hitechgs3t's Avatar
how did u get it to work...i would love to know thanks
Old 06-04-07, 08:23 PM
hiendo85
hiendo85's Avatar
ok, there are 4 wires that you need to cut...
1st plug on the back of your nav unit is called k47, you need to cut 3 wires on this plug. this 3 wires are all come from the back up camera as you can see in the detail of the 1st plug k47. and the wires that are to be cut are red, white and black. the red and white wire are video input from your after market dvd..
2nd plug on the back of the nav unit called h1, this is the plug where you can also do the nav hack...but on this plug for this mod, you need to cut the silver wire with silver dot on it and connect to a +12v then connect throuh=gh a switch to activate the back up camera even though youre not in reverse mode. the +12v is to trigger the camera even when it is not in reverse.
1st plug.....K47 on your Multi-Display (Signal = Connector & PIN # = Wire Color):
Nothing interesting here. This connector contains signals from the voice guidance, the backup camera, DVD image signal and Microphone stuff.
2nd plug.....h1 (not "H1") on your Nav ECU & Multi-Display (Signal = Connector & PIN # = Wire Color):
GND = h1 PIN 6 = G
SPD = h1 PIN 16 = W-B
(Provided FYI only): REV = h1 PIN 15 = GR-B
Note: There is no PKB signal present on connector h1
make sense ??? need more help let me know, i believe im the first one to be successfull in this mod for this car.
ill take picture later and show yall what i am talking about, but with that above you should be able to do this mod if you are talented...hahaha. ill post picture tomorrow
Old 06-04-07, 08:25 PM
hiendo85
hiendo85's Avatar
this mod will only works on 07 gs350....06 gs300 people be aware of this... if i have the wiring diagram of the 06, i might be able to figure it out...because the '06 is totally different from the '07..
Old 06-04-07, 08:27 PM
hiendo85
hiendo85's Avatar
here is a link to the plugs.. just to give you an idea how the plug looks..
https://www.clublexus.com/forums/sho...light=nav+hack
post #2
Old 06-04-07, 09:09 PM
bozer
bozer's Avatar
Damn Hiendo.. wish I knew you or you lived near NYC. Im too scared to do this myself
Old 06-04-07, 10:49 PM
istundra
istundra's Avatar
Does this require an External Video Source?
How do you play DVD's when the indash changer is CD only?
Is this mod through the Rear Camera Video Input?
Audio via FM Modulator?
Thank you so much for your help!
Paypal donations for funding the R&D of this mod?
Old 06-04-07, 11:58 PM
phattbam
phattbam's Avatar
very interested in this now..
Old 06-05-07, 12:03 AM
istundra
istundra's Avatar
If this is what I think it is... It will always display "Check Your Surroundings" whenever you activate the Input.
Old 06-05-07, 06:29 PM
hiendo85
hiendo85's Avatar
1. you use an after market dvd player
2. yes
3. yes
i think you can do it, need anything else, let me know..
Quick Reply: Non Ml System Use To Play Dvd Through Nav Screen
