garage door
I have a rolling code and I hit the training button as well, and neither of my 3 doors will link to the car. Works with the GX and even the landcruiser, but not my the GS450h.
bah.
bah.
In trying to get my GS350 to recognize my son's garage door opener, I discovered that the only way it would accept the rolling code was by driving my car inside his garage. Once there, it was a cinch.
While trying to get it to work with my car outside of his garage, it erased the codes from both his cars. They had to be reset in order to open the garage door.
Go to homelink.com and you will find a way to get it done.
Thank You.
u must have the hand held remote in order to get it work,go home depot buy one reprogram and put it away for future needed.that what this to my and it worked like a champ.
I have had no problem setting up with my rolling code openers outside of my garage or my non-rolling code gate. If your opener does not have a learn button on it, it's probably not rolling code and you need to use your original remote to program the opener. Even if it is rolling code, you still need the original remote before doing the step with the "learn" button on the opener.
According to the GS350 manual, you need to hold the training button on the door opener. Press and release the vehicle's HomeLink button twice. The garage door may open. If not, press and release the button a third time. The third press and release will complete the programming process by opening the door. Page 3-7 of the manual.
Anyone with other suggestions, please come forward. It appears that some cars may need a different way of programming the buttons.
I use the handheld opener...... so old school right?.... ha
I had a bit of trouble programming mine. I was about 3 feet outside of my garage and perpendicular to it. I used the handheld remote opener and held it as the manual suggested within 3 inches of the mirror and held the 1 button down and then held down the opener button. It took it about 30 seconds for the light under the mirror to even start flashing, and then about 60 seconds after that it started flashing rapidly.
I suppose I should have followed the manual and put a new 9 volt battery in the remote, but the garage door sure was opening and closing throughout the whole ordeal.
Either way it works really well and the Lexus transmitter works from a lot farther away than the old remote, so I'm thankful for that!
I tried it with and without the original remote control. Only way it worked for me was by parking the car almost directly under the door opener. That's also the way my son programmed his wife's RX350 and his ACURA TL.
1. Hold down the Homelink button that you want to program until it flashes at a slow rate.
2. Once it starts to flash, do not let go of the button and now hold down the button you wish to program on your handheld remote control unit. Use caution because the button will activate whatever it normally activates so make sure there is nothing under the garage door or anything. While holding both buttons, the homelink light will flash rapidly indicating that in-car programming is complete.
3. Go to the garage door opener motor housing and press the learn button briefly and the LED will start flashing indicating that it is in learning mode.
4. Go to the car and press the in-car Homelink button that you previously programmed. The light on the garage door opener should flash indicating that programming is completed.
Distance is not an issue at all so the car does not need to be in the garage to do this. The only reason for wanting the car close that I can think of is that you get a certain amount of time after pressing the learn button so if your car is way down the driveway, you might have to run to press the in-car homelink button.
I am on vacation right now so I can't tell you what the manual says but forget all of that and use the instructions above.
