Cabin air filter replace for GS350
Not cabin..you can go 20k before you need to change one...
I think I broke mine when replacing it..can't remember if recirc button was one of off..it was awhile ago. But i know recirc doesn't seems to block bad smell from outside anymore ahhaha
You can order this through our own CL Vendor, Sewell Lexus.
Part# 87139-07010
http://beta.lexus-parts.com/parts_detail.asp?id=89330
Part# 87139-07010
I think my number is old.
I bought "carbon" filter 08974-00820
http://s3.images.drive2.ru/car.journ...e777-large.jpg
Left - stock after 7k miles.
Right - new carbon filter
This is my first post!!! I just purchased a 2008 GS 350 AWD a month ago. Love how it drives!!!! However, I noticed that I when I would hit the recirculation button ... the outside air would still come through the vents. Took it to one dealer in Richmond, VA and he never heard of the problem and said that all cars do that. I quickly gave him the "gas face" and rolled out. Took it to Lexus of Alexandria and they knew what the problem was right away. Said that someone did what the guy did in the you tube video and quoted me for $1400!!! WTF ... Has anyone figured out how to fix this problem (beside trading it in ... LOL)?
I bought the carbon one too and I have no more bad smelling A/C. It's AMAZING. Not gonna put in anything else but that carbon filter now.
Some guy dismantled the A/C assembly, found the gear that broke and then glued the piece back together and it worked. Or you can try buying just that gear and fixing it as well.
https://www.clublexus.com/forums/gs-...glove-box.html
I know you can buy just that little part from a dealer.
Cabin Air Filter
They can be purchased thru many different vendors on line for around $12.00. Set ventaltion system in "recirulation mode" and remove and replace the old according to the instructions in the manual. Less than a 5 minute job!
I usually go through Sewell. They give a big discount for clublexus members! $42.29
http://lexus.sewellparts.com/accesso...2007/2518.html
I replaced the cabin filter a few times. But this time the filter I installed does not have an UP arrow.
Instead it has an AIR FLOW arrow.
Can anyone confirm the air flow direction is downward from the cabin air filter casing.
Thanks.
Thanks.
http://lexus.sewellparts.com/pdf/ac_filter-2.pdf
According to Sewell installation it shows Air flow/All arrows pointing UP. <see link below>
After seeing this video, I am very sure the air flow direction is from top to bottom.
If the air flow is from top to bottom, the filter would have a hard time to stay in the casing.
I know about the UP arrow in the manual and some filter. The UP arrow on the filter is not necessary an indication of the air flow direction.
http://www.youtube.com/watch?v=XmfjIPt7UsA
The dirt was trap on top of the old filter when I removed it. That confirmed it.
