Turn by Turn guidance not working
Diag 2 is right and now that i see this, you should not have to have a switch, check your connection, if you did initially cut and tap into the pink, you should be fine
i initially thought you cut the purple and yellow and that was it.....you had written:
Edit: I only did the DVD/Blutotooth bypass, NOT THE NAVI. Reading this thread didnt help.
if you did what is in diag 2 (w/o a switch), you should have smooth scrollling nav already, like i said, maybe a connection issue
netcbc
RX - 3rd Gen (2010-2015)
10-05-15 07:27 AM
