Body Rattles - DIY thread
#64
Back from the dead. I just bought a 2011 GS350 and there are two rattles driving me wonky. One was coming from the dash when going over bumpy roads. I pulled the instrument cluster trim off and tapped on the top of the dash, pushing and prodding until I found the culprit - the cluster itself. I wedged a piece of very dense foam between the bottom of the cluster and a plastic duct that runs horizontally under it. Problem solved!
Now to find the source of the "golf ball" clunking around in the back somewhere. I can't determine yet exactly where it comes from or what causes it. I think it might be a toughie.
EDIT: Who buys a Lexus expecting squeaks and rattles?!? Even a used one. Nobody that's who.
#65
Having been a Very Happy Hyundai Genesis Owner for 5 years, I now own 2 Genesis and have never had a rattle problem or any other problem for that matter. I am a Confirmed Genesis Owner. I have 70K miles on my 2011 and it is problem and rattle free as the day I bought it about 6 years ago. I bought a 2014 Genesis about 2 years ago and love it.
Lexus Lost its Luster about 2003.............
#66
Yea, I went from an 02 LS to an 07 GS350 AWD ~ 2 months ago (rest her soul) and I'm still in shock at the NVH in this beast.
Comparing from my experience taking the LS apart (tho it was rarely needed), it's actually true when people say the GS isn't "put together" as well as the LS.
It seems like the trim and covers are well designed to fit elegantly and cleanly but not tightly/securely.
I've hunted down and fixed most of the noises, but two still elude me.
One seems to be in the left C-pillar. I'll go in there this weekend and try to get that one gone. Kind of a ticking sound that's triggered by the car rocking gently but not by impacts and bumps.
The other is the sunroof. Just seems... loose. Already tightened the two rear mounting bolts, need to get to the others now.
Bah. At least I enjoy the work.
Also glad I bought this as a holdover until an LS460 next year.
Now not sure if I want to search for an 05/06 LS430 instead...
Don't know whether to trust this generation of Lexus cars.
#68
If the mirror is loose there's a hex screw that faces downward that you should tighten to start.
It's on the stalk that connects the mirror to the glass (behind the garage door buttons).
There's a small hole you'll find if you put your head up under the mirror.
#69
My next noise is not a clunk or rattle. It's a whine or moan from the engine compartment when the throttle is just barely cracked open. For example when maintaining 45-50mph on a flat road. Lift completely and the noise goes away. Press hard enough to accelerate and the noise goes away. It is definitely in the 'just turn up the radio' range but I'm curious and will do some research to see if I can find out anything.
#70
I have found a fix now that took 5mins 😀
Happy to share if anyone has the problem.
#71
How do you pull the cluster trim off?
Thanks.
#72
![](https://cimg0.ibsrv.net/gimg/www.clublexus.com-vbulletin/2000x1504/lexus_windshield_alignment_clip_noise_5a2e37721b457fd3e8988479a2f6f4369a8327b7.jpg)
Just found one of the most annoying clicking noises I've had for a long time that I COULD not find. There are plastic tabs glued onto the windshield for alignment and they push down into metal slots/tabs on the roof. It was making a clicking noise when the body would flex. Had to pull my front pass visor down and the center overhead console.
2010rouge
02-03-17 11:04 PM
