Rear end noises
Rear end noises
My 2007 Gs350 has a very loud rattle when you go over bumps coming from the back tire area. The dealership ssaid it was the calipers and these are normal noises. It sounds like a a rattle with nuts and bolts insdie of it. Does anybody else have this problem and what was the solution to this noise?
Thanks
Thanks
i'd get in ther eand check. probably just something loose, like you mentioned. I have had that problem in a previous car, when they gave me the same excuse as they gave you, and I found some bolts that just needed tightening in the end.
good luck, let us know.
hey rkling, I have a gs350 aswell and don't have any noise in the rear, did you check your spare tire and all equipment that is with it? wheel lock, jack, tire iron, etc, lots of pieces back there to rattle around...
