3rd Gen GS Nav Bluetooth DVD mods thread
Old 05-17-10, 12:31 PM
  #166
Rengozu
Rengozu's Avatar
Originally Posted by EyeKutr
For 07+ GS….HERE IS THE WIRE MOD FOR NAV
you cut the white with silver dots wire (middle harness) and purple wire (driver side harness) then you use a switch to connect the purple wire coming from the deep side of the dash (not radio) to the white with silver spots (going away from the radio (to the nav). then this switch is on all the time except to input addresses, what that does is it allows the purple VSS signal to go to the nav See diagrams and pics (thanks to quezacotl for dgm)
Here is the switch I used, came from a 3.5inch external HDD enclosure I had
DVD override: If you have done the wire modification for nav, you have already taken the speed signal away from the cd / dvd changer. All you need to do additionally to allow DVD video in motion is to trick the dvd changer to think that the parking brake is applied. All you need to do is to ground the yellow parking brake wire. You cut the yellow wire in pics and attach a grounding connector (and wire extension) to the side that goes to the radio display and ground it to chassis. This way, car thinks it is not moving and the parking brake is applied (no dash lights come on) and lets your family watch DVD while car is in motion.
Is this still the best method for the Nav override?
I have a 2007 AWD GS350 w/ Nav and ML
I just ordered the VAIS ipod adaptor and want to be able to use the screen while driving.
Just wanted to make sure there's not a newer, more effective route I should
take. thanks!
Old 05-17-10, 07:09 PM
  #167
EyeKutr
EyeKutr's Avatar
It is indeed, you can buy the prestigious society kit to spare the cutting
Old 05-17-10, 10:18 PM
  #168
Rengozu
Rengozu's Avatar
Cutting doesn't really bother me as long as everything functions as needed when finished. Just wanted to make sure there wasn't a newer,better technique I was overlooking.
Thanks, and wish me luck!
WOW! I DID IT! - Took a lot more time than most of you, but for a rookie at this I pulled through nicely with no problems. Thanks for everyone involved in making these guides so the handicapped like me can do it too!
Woo Ipod + DVD + Nav override!! I'm lovin it!
Old 10-14-10, 08:34 AM
  #169
GSLEX0586
GSLEX0586's Avatar
sorry if this is newb, but i wanna get this straight before i pull out my entire dash and hack a $4,000 system....
for 2006 GS with ML and NAV....
i basically have to cut 2 wires (pink and purple), lead the sides coming from the car(not radio) to a simple switch. then simply ground the yellow cable (for dvd hack) and im done???
Old 10-14-10, 09:48 AM
  #170
IXI187IXI
IXI187IXI's Avatar
i dont think the wire cut will allow for unlimited time like the PS kit will. not sure so i'll let someone else comment on that.
Old 10-14-10, 10:11 AM
  #171
GSLEX0586
GSLEX0586's Avatar
what do u mean by unlimited time??
Old 10-14-10, 05:34 PM
  #172
CalCounsel
CalCounsel's Avatar
I have a 2007 GS350 w/ML & Nav & XM Radio.
I want to perform the DVD override, but I am also considering installing the SL2iC (Native Video Interface for iPod touch and iPhone) whenever it comes out.
My questions are--(1) are there installation overlaps (wires and/or otherwise) between the SL2iC and the DVD override? Should I wait to perform the DVD override until the SL2iC comes out aside from not having to pull apart the nav unit twice?
Thanks in advance.
Old 10-14-10, 09:22 PM
  #173
micnn
micnn's Avatar
That's right. The hack will stay active for about 3 minutes or so, so a switch is needed to do a switch on / off cycle and the hack will come back active.
Old 10-14-10, 09:31 PM
  #174
GSLEX0586
GSLEX0586's Avatar
So in order for dvds to be played in motion this hack isnt an ideal option?
Old 10-15-10, 12:07 AM
  #175
rominl
exclusive matchup
rominl's Avatar
Thanks in advance.
you don't need one before doing another. but i would just do all together coz' you are taking off the same stuff.
can be as little as 45 secs. i have seen people with cut wire, it depends on speed, and at above 40mph or so, after 45 seconds the nav override went away
Old 10-15-10, 03:48 AM
  #176
GSLEX0586
GSLEX0586's Avatar
so just to verify - my movie could be playing for as little as 40secs-3min while in motion?
Old 10-15-10, 04:16 AM
  #177
IXI187IXI
IXI187IXI's Avatar
with the wire hack yes. you have an 06 so you really dont need the wire hack for the navi override. you can just do the "finger dance" for the screen to access the override button for the navi portion. this is strictly for navi though, not movies.
Old 10-15-10, 08:37 AM
  #178
GSLEX0586
GSLEX0586's Avatar
yea i dont really care too much for the navi override becuz i use my android phone for navigation (but it wouldnt hurt to have the enter-while-in-motion feature), but the main reason i wanted to do this was so i can have my passengers watch movies on long road trips, but if its gonna cut off in 40secs, no point in doing this!
btw, from what i recall, the navi override you're speaking of isnt retained in memory though, is it? i recall reading the DIY section and it says u need to do that everytime u start the car, correct?
Old 10-15-10, 08:41 AM
  #179
IXI187IXI
IXI187IXI's Avatar
yup. it literally takes 10 seconds to do though. plus it allows you to enter phone numbers while driving too.
Old 10-15-10, 08:53 AM
  #180
GSLEX0586
GSLEX0586's Avatar
so just to RE-confirm, i wanted to do this hack for the ability to play DVDs while in motion, but it will cut-off so dont even bother?
Quick Reply: 3rd Gen GS Nav Bluetooth DVD mods thread
