cry02 - interesting
CryO2 Cryogenic Air Intake
The CryO2 Air Intake segments mount right in the air stream using silicone sleeves. They consists of an aerodynamically designed bulb with a cryogenic chamber which is mounted in a 4" segment of air tube.
Product Description
The CryO2 Air Intake consists of an aerodynamically designed bulb with a cryogenic chamber which is mounted in a 4" segment of air tube. The air passes over the bulb, heat is removed from the air charge resulting in a colder, denser, more powerful charge. Dyno testing showed a reduction in intake air temperature of more than 50 degrees. The CryO2 Air Intake can be used on turbocharged, supercharged or naturally aspirated applications. Multiple units can be used for colder results. Installs in minutes and comes with silicone connection sleeve, hose clamps and connection / vent hose.
http://www.designengineering.com/pro...sp&pid=4&tid=1
Product Description
