Is there a Forced induction 3rd gen out there yet?
As the title says.
I am looking to either get a 2nd gen and do a Swap, or get a 3rd gen and see what the options are. I want the AWD so it is a year round car. But need the power. anyone with any ideas?
Lexus Connoisseur
Yes, there are two GS' that were debut at SEMA by Lexus.
The Greddy GS:
![](http://tyt.tnpv.net/Image/2007/10/TYT2007103032721_PV.jpg)
![](http://tyt.tnpv.net/Image/2007/10/TYT2007103093400_PV.jpg)
The Blitz GS:
![](http://tyt.tnpv.net/Image/2007/10/TYT2007103044385_PV.jpg)
The Greddy GS:
The Blitz GS:
![](http://tyt.tnpv.net/Image/2007/10/TYT2007103071607_PV.jpg)
Lexus Connoisseur
Blitz GS:
Engine
• Blitz Twin Supercharger System – Prototype
-Electronic Clutch type system with activation selector
switch
Normal HP/TQ (flywheel) = 290 hp / 319 lb-ft
*Estimated HP/TQ (flywheel) = 363 hp / 415 lb-ft
• Blitz Sonic Power Air Cleaner
-Adjustable Velocity stack intake utilizing a cotton fiber filter
• Blitz Iridium Spec 77 Spark Plugs
-Iridium Spark plugs with heat range 7
• Blitz Nur Spec DT Exhaust System
-Full stainless-steel system with a dual rolled tip
• Blitz Radiator Cap
-High pressure racing radiator cap – holds up to 18.4 psi
• Blitz Oil filler Cap
-Made of forged billet aluminum
Electronics
• Blitz RVIT DS – Prototype
-OBD2 Port reader with limited CAN BUS Controllability
-Utilizes Factory Navigation Screen to view ECU
Information
• Blitz TV/NAVI Jumper – Prototype
-Allows driver to view dvd/aux input while vehicle is in
motion
• Blitz Power Meter i-Color
-Calculates horsepower up to 1200 hp. Features peak
hold, warning, and rec/replay functions
Suspension
• Blitz Super Flex Lowering Springs
Front: ~1.0” Rear: ~ 0.75”
Wheels
• Blitz BRW Profile 09
-CAD Designed 1-piece cast wheels
Front: 20 x 9 +38 -Deep Chrome Coating
245/35/20 Falken FK-452
Rear: 20 x 10 +40 -Deep Chrome Coating
275/30/20 Falken FK-452
Exterior
• Blitz Carbon fiber front grill w/ emblem base
• Blitz Front Lip Spoiler
• Blitz Side Skirts and Rear valence – Prototype
• Blitz i-Burner Illusion LED Lights
-User controlled LED lights with multiple color output
Engine
switch
Electronics
Information
motion
Suspension
Wheels
Exterior
Lexus Connoisseur
GReddy GS:
Engine
• 4.3L Supercharger Kit
• Street Performance Stainless Steel Cat-Back Exhaust
• Stainless Steel Headers (Exh. Manifolds)
• Airinx GT high performance drop in filter
Electronics
• E-Manage Ultimate engine control unit
• Informeter OBD2 data-reader
• Electronic Meters – boost, egt, oil press, fuel press
Brakes and Suspension
• Front Brake Kit - 6 piston calipers w/ 355mm rotors
• Type-S Coil-over suspension kit
• Strut Tower Bar Rear
Exterior
• GRacer Aero Lip Spoiler
• Volk Racing GT-F 19x8.5, 19x9.5
• High Performance Luxury Tires
• SF-X style Graphics
• Black Roof Top
Interior
• Full Audio & Visual System (monitors, DVD, Speakers, etc.)
• Suede seat accents
• Color match interior Trim
Misc.
• Stainless Steel Hoses & Fittings
• Custom Engine Cover
Engine
Electronics
Exterior
• Black Roof Top
Interior
Misc.
Lexus Connoisseur
Tom's Hyper Compressor - GS430:
![](http://www.tomsracing.co.jp/e/arcive/2007/01_18_5/img2.jpg)
■CHARACTAER
• Achievement of MAXIMUM POWER 250kw(340PS) MAXIMUM TORQUE 540N・m(55.0kef・m)(Office measured value of a full option state)
• We realize the powerful acceleration that is faithful to an accelerator work than a pole low speed range.
• It is coexistence in high calm characteristics of (idling, accelerator off time) and the mileage characteristics saving at a response and the low load time when it is sharp by adoption of an electromagnetic clutch controlled in exclusive ECU.
• We suppress a rise of intake temperature by water-cooling intercooler adoption and show stable performance.
• For the complete bolt on kit, which made the main body of compressor, an installation bracket, piping, an exclusive computer a set, installation is simple ness.
Tom's Hyper Compressor - GS350:
![](http://www.tomsracing.co.jp/e/arcive/2007/01_18_3/img2.jpg)
■CHARACTAER
• Achievement of MAXIMUM POWER 263kw(358PS) MAXIMUM TORQUE 488N・m(49.8kgf・m)(Office measured value of a full option state)
■CHARACTAER
■CHARACTAER
Lexus Connoisseur
Mind you all of these were specifically made for Lexus Japan vehicles.
Lexus Connoisseur
The Tom's kit which has not been tested to work with the US-spec ECU's, retail price is $10,000 good for about 50hp only.
Lexus Connoisseur
The blitz package will probably go for around 6-7k without install. I have realized after dumping close to 16k into g35 sedan that I made into a race car that I could have just bought a faster car. also forced induction is not as reliable as they make it out to be. no matter what kind of power you have after a couple of months you will start wanting more. wanting more means more boost, which results in smaller pulley for the supercharger or more boost dialed in on your boost controller(or larger intercooler, nitrous,cryo intercooler sprays, larger down pipes ...yada yada yada... the list goes on and on. Bottom line is you will normally push forced induction until you blow the motor. The stock bottom end and fuel system of a normally aspirated car are not made for large boost. I have seen at least 9 or 10 guys who have run twin turbo,s/c kits on the g35s and 350 z and they eventually cause engine failure and have to rebuild. I agree driving a tuned car is more fun, but to an extent. I still think about my old g35 all the time, but i love my lexus. I think the car looks feminine and a little weak with 18's and the stock ride height but that will all change soon. If you had to do it, go with the 2nd gen with a 2jzgte swap. Good luck!!
If you want the AWD and do forced induction, your best bet is to get a 06 GS300 AWD and do a custom super or twin turbo charging. Throw in lower compression forged pistons and high boost and we are talking some serious AWD power sedan.
Problem with 07-08 GS350 is that it's got the very high compression direct injection engine and it's hard to do a forced induction on these DI engines because I believe you can't just throw in lower compression pistons into these DI engines like you would do with traditional port injection engines. That's why you see these kits made only for GS430 which is non-DI engines, exception of Tom's Hyper Compressor - GS350 kit which can only give you like 50hp for nearly $10,000. Very expensive for mere 50hp probably for above reasons.
Hate to do this but I recommend getting something else like BMW 135xi, 335ix or 535ix as it's already got the turbo charged engine and AWD and even with little bit of tuning, you can easily get 350 hp no problem with this car. By factory turbo charging this engine, it's already becoming a tuner's dream and it wont' be too long before someone cracks the ECU if no one hasn't done it already.
