Aftermarket Wheels + TPMS ??
I know a handful of you owners have installed aftermarket Wheels. My question is what Tire Pressure Monitoring System (TPMS) did you install on your new wheels to not cause the warning light in the dash to go crazy?
Can you provide price and compatibility? Did anyone try TireRack?
Thanks,
Rich
Thanks,
Rich
My understanding is that the tire pressure monitor sensors can come off your old wheels and onto your new wheels. Or, you can purchase new sensors, but need them registered to your car by the dealer. I'm going to try and have my existing sensors put onto the new wheels when they come in.
Most people will take the ones in your stock wheels and place them in the new set of wheels. I went and got another set of TPMS and had them "programmed" them to my car. I have the sensors... just awaiting my wheels within the week.
With aftermarket wheels, you will need a special valve that is designed to hold the TPMS or be forced to drill the rim so it can accommodate the sensor. I had both option but I chose to get the special valve.
Each sensor new is a little over 100 bucks but u can find them on ebay from 50-150 for a full set of used ones. Remember to get them programmed to your car before you install them, otherwise they will have to charge u to dismount the tires and do it the proper way.
I went to a local America's tire (same as discount tire) they have a huge poster explaining TPMS during wheel/tires installation, so I would assume they know exactly what to do with it.
Currently, no there is no way to turn off the TPMS. There have been other ways around it. For example, "TPMS Bomb" its a funny title but it works. What they do it place a set of sensors in a round cylinder or threaded pipe and enclose it with screw on ends. Some weld it close. From there *** I believe *** they fill it with XX amount of psi to prevent the sensors from going off.
Then there is the wheel barrel method, which again the TPMS are enclosed within the wheel and the air pressure is adjusted.
Its a safety feature that we already paid for... why not use it for what it was meant to be.
I like the idea of TPMS for my new TOM's 19" wheels. I just dont want to have to drill or damage the wheels to have them successfully work.
IF that turns out to be the case, I will build the TMPS bomb as you put it out of PVC, pipe and caps and install one of my spare SSR screw on type valve stems through a correct sized hole drilled in one PVC cap prior to me blue-glue ing it together.
I been reading up on this and I am wondering if we can use any Ford, Chevy, Jeep sensor? I rather use a Toyota part but I dont see them on eBay too often. I just want to be economical in this matter.
Toyota/Lexus sensors only. You gotta keep up on eBay, I got my set for $60 shipped. ![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
BTW make sure that PVC TPMS bomb can handle air pressure. I believe in the 3GS you can hit a switch to reset the air pressure or something along that line. I saw it as I paged through the manual but can't remember it all correctly.
Lexus Connoisseur
Always best to have a 2nd set of TPMS for your aftermarket wheels just in case. Otherwise you will get the annoying TPMS dash warning light to stay on while you drive.
Go with the OEM Lexus sensors. Make sure it's the right one for your particular GS (i.e. build date).
Expect to pay over $300 at a minimum for brand new sensors. Look in the vendors section, they have them. I think swell lexus is selling them for $3XX.
