GS460 Question
GS460 Question
I'm getting tired of driving the SUV and I will be going to test ride the GS460 on Monday. Has Lexus allowed the VDIM to be turned off? I thought I read that somewhere. Maybe it was for the IS?
Also does the lawyer disclaimer disappear after a few seconds on the nav system for the 08 models?
While I'm at the dealer, I might also try out the IS350.
Thanks, it does. I read some test reports on the GS when it first came out and it said the Traction/VSC was so intrusive, it affected their track times. Not that I intend to ever take the car to the track
In the 2 days of ownership on the GS, I realized it is not quite a "performance" vehicle. Initially not being able to turn off VDIM, was certainly a turn off, but I got over it. It's really a nice lux car with some performance aspects to it.
Guest
Posts: n/a
Actually it's the VSC/TRAC defeat, not VDIM defeat. The GS350 does not have VDIM hence it's the VSC/TRAC defeat. The operation to defeat it is to hold the TRAC button down for 3 seconds and both VSC and TRAC lights will appear on the dash. This is a feature available on the 07 and newer models.
1st there is the VSC Button which you can press once.....
2nd.. park mode press the VSC button for ten seconds
3rd n best.... DO EVERYTHING QUICK
1.Hand brake should be on.
2. Start your car with your leg on the Brake
3. push handbrake n release 1st time
4.push handbrake n release 2nd time
5. hit the brake 2 times
6. push handbrake n release 1st time
7.push handbrake n release 2nd time
8.hit the brake 2 times
you will see the VSC and something new that has ((!))
BE CAREFUL YOUR GONNA DRIFT FOREVER
There are 3 traction controls in the GS430
wow hey, you are right!!!! now i feel good that my car has vdim! seems like it's standard on all gs now
i am going to look at the 07 brochure (have it at home) and see what it says
Drive Wheels -Rear, with standard Vehicle Dynamics Integrated Management
(VDIM)4 (GS 460, GS 350 RWD)
Full-time all-wheel drive, with standard Vehicle Dynamics Integrated
Management (VDIM)4 (GS 350 AWD)
But doing the VSC/TRAC defeat is not a VDIM off function.
