Are front calipers on '06-'08 GS350 as big as on GS430?
Old 01-07-08, 01:47 PM
WhitBaby
WhitBaby's Avatar
Default Are front calipers on '06-'08 GS350 as big as on GS430?
I got a set of 17" Miglia's that I just love but they won't quite fit over the big-assed front calipers (aka BBK's) on my '06 GS430, even with 15 mm spacers.
I'm gonna try to sell them but want to know if they might fit the 350's.
Below is a pic, obviously the wheels aren't actually mounted.
Thanks,
Whit
Attached Thumbnails Are front calipers on '06-'08 GS350 as big as on GS430?-cimg0008small.jpg
Last edited by WhitBaby; 01-07-08 at 02:13 PM. Reason: Pic didn't come through...was too big.
Old 01-07-08, 01:49 PM
ek9vboi
ek9vboi's Avatar
17s" sounds tiny. lol, my gs350 has 18s from the factory. i believe the 350 calipers are the same as the 430/460s.
maybe its my laptop, i dont see a pic.
Old 01-07-08, 01:56 PM
WhitBaby
WhitBaby's Avatar
My GS430 originally came with 18's too, but previous owner had them changed to 17's to soften the ride and reduce chances of dings in potholes.
No my pic isn't coming through for some reason, even after editing.
I'll try again here.
Whit
Old 01-07-08, 03:08 PM
rominl
exclusive matchup
rominl's Avatar
i believe they are all the same, at least very close. if the wheels don't fit your gs430, i don't think they will fit 350
Old 01-07-08, 08:12 PM
flipside909
Lexus Connoisseur
flipside909's Avatar
What are the offsets?
Old 01-07-08, 08:18 PM
EyeKutr
EyeKutr's Avatar
The gs430 and gs350 share the same brake setup, the 06 gs300 had smaller calipers so that may work
Old 01-07-08, 09:08 PM
rominl
exclusive matchup
rominl's Avatar
offset is not the problem, like it's the disk type
Old 01-08-08, 05:56 AM
Yang1815
Yang1815's Avatar
I thought the 08 350 also has smaller brakes in the front?
Old 01-08-08, 09:17 AM
rominl
exclusive matchup
rominl's Avatar
nop, i don't think so. i still have pretty darn big calipers up front. doesn't make sense for lexus to spend more money to make yet another caliper
Old 01-08-08, 10:03 AM
WhitBaby
WhitBaby's Avatar
The wheels are 17 x 8". The backset is 6", so the offset is about +50 mm.
The clearance problem is between the outside of the calipers and inside of the wheels. These wheels have a very slight taper on the inside which causes the problem when the wheel is just about to seat on the flange.
The 15 mm spacer helps but not enough to clear and I don't want to use bigger spacers than that or shave the calipers. Suppose I could put the wheels on a lathe...NOT ;->
Whit
Old 01-08-08, 10:21 AM
rominl
exclusive matchup
rominl's Avatar
Whit
from your descriptions, the wheels is a standard disk
Old 01-08-08, 11:24 AM
socalJD
socalJD's Avatar
They won't fit a GS350 (or IS350). They should fit on a GS300 or IS250 . . .
wmr71
05-15-13 07:14 AM
mikegs2006
08-08-11 07:09 PM
cpcalkins
11-17-10 08:45 AM
Quick Reply: Are front calipers on '06-'08 GS350 as big as on GS430?
