jl audio sound system gs350 . yes or no ?
That's 2x 12W6V2 in my old E55. It rattles b/c of the license plate and frame. Otherwise it was good http://www.youtube.com/watch?v=81muFVAMUB4
Porting typically makes it alot louder, but boomier. A sealed enclosure will be more accurate and tight, but not quite as loud as ported (given same size/specs).
Depends on the type of music you listen to mostly.
I listen to a wide variety. From rap and hip-hop, to punk, to mellow rock. Whatever I'm in the mood for. I have 2 10"s in my truck now. I'm thinking of going with one 12" W6. I'm guessing in a sealed box with fiberglass resin like my 10s in my truck.
Rap and hip-hop normally sound really good with a ported enclosure since it's naturally "boomy" music. Mellow rock, jazz, classical will probably sound better with a sealed enclosure for accuracy.
In my old car, I went from 1 10" JL W6...wasn't enough.
Then did 2 12" W6....started losing my hearing after 1 month.
Ended up with 1 12" W6...was perfect for me.
All were sealed enclosures (my preference).
If you're on the fence about ported or sealed...you can try and listen to a few different types are your local car audio shop to get an idea.
I prefer a tight and on note sound. small and sealed would be best... for me anyways. lol. even though i dont use my trunk much, i still like the idea of having a whole trunk without sharing it with a sub and amp.
I have 2 8w7's ported thru the rear deck.It's powered by a 500/1.It's alot better than stock.I think I should have got a sealed enclosure,it plays alot deeper but not as tight.The low end over comes the mids & highs.
ByoungWoo
02-21-08 07:49 PM
