Fixed my wheel vibration/shaking problem.
For those who have lowered and added aftermarket wheels that are getting a shaking for vibrating problem, here are more things to do if this happens to you. Given this will not happen to everyone, my case is different as with everyone else.
So I got my wheels and put them on. Violent shaking from 60mph+.
1st fix: I was given the wrong hub rings with my wheels. So I got the proper hub rings and it helped a little. 70mph+ shaking
2nd fix: I was told to road force balance my wheels. Did this and the wheels came out PERFECTLY balanced. Not really a fix. lol
3rd fix: While I was at the wheel shop they checked my hub rings. Turns out I got the right hub rings 60.1 bore, BUT it had a little play in it. So they got me another set of hub rings, which were 60.06. Installed and they sit perfectly.
4th fix: Turns out my lugnuts were not the proper ones to be used. Geez... my expensive lugnuts. So they showed me another lugnut:
They install it in the fronts only because they only had 10. Still got my lugnuts in the rear.
Jumped on the highway and tada.... 0-80mph no shaking or anything close to it. I am happy, but it wasn't cheap. Time for tints and the alignment,
man I went through a similar situation with a set of asanti's. I went back 8 times and finally got the money back for the wheels. I odered a set through a wheel and tire shop that does only high end cars for dealerships. I have a feeling they will do a better job than discount tire. When I pulled into the shop they had three Lorinser tuned Benzs , a Ferrari F430, and a Bently all getting new shoes. I am glad you got it figured out. I know how frustrating it can be. My new wheels should be in this week. I am praying things will go more smoothly. You would be surprised how much these little things like lug nuts and the worlds smallest amount of play in a hub ring will still cause enough vibration for someone to feel it. Again I am glad you got it sorted out.
http://www.aj-racing.com/catalog/pro...3&cat=6&page=2
LOL, that is a picture of the lugnut I found on google. The only way those wheels are going to go on my car is if im at the track with crazy HP on the GS. rears ONLY because i wanna look good in the front while going down the strip.
fixed my shaking too. i thought i had a balancing problem but turned out to by something with the tire side wall not sitting flat with the lip of the wheels. so i was losing air really slowly and it was causing a shaking wobbling feeling from the rear of my car.
Lexus Connoisseur
I use McGard Splinedrive lugs on my aftermarket wheels. The cheaper "tuner" lugs tend to be made of poor quality and are manufactured with pretty low quality standards. McGard is an O.E. supplier for Toyota/Lexus wheel locks and lugs.
I went through a huge lug nut issue with
aftermarket wheels on my BMW 745. Discount Tire had told me my stock lugs were too short so they put on some other lugs. They had put on some that were too long and it was hitting against my rotor. Freaking idiots. I had taken it up there because of a loud noise coming from my wheels. Be very careful when you put on aftermarket wheels...
Yeah, they cost that much... BUT did I pay that much. No where close to it.
I have those T1R's also, but IMO open ended lugs look better on a more race/performance oriented car. One that possibly has extended studs, therefore requiring the open ended lugs. For the Lexus, I prefer these lugs. The base spins also, just like the Project Kics.
I know a lot of people including myself are having problem with the shaking at 60 mph. I am running on the stock 16 with stock lugs. I also have the 19 g35 wheels and i also run them with the stock lugs, I also get the shaking. I know there are issues with the g35 on centric hub. but what explains the shaking on the stock 16s with stock lugs. If it is the lugs then I should not get any shaking on the stock wheels. what do you think
