Please Help * 5.1/7/1 Hybrid Disk Stuck in Nav Unit + Not Loading
Hello All. Well I used the search function which showed me to how succussfully backup my original disks, I always run backups so i dont scratch my originals. Anyways after much reading I decided to make a 5.1/7.1 map disk and see if I could get it to work on the Gen5 Nav which a few others have reported as working. I disconnected the left batter terminal for 5 minutes, replugggd and then when I got in the car it told me no nav disk, or operting system or soemthing like that. I threw in my hybrid disk figuring it would start to load but it seems to just be sitting there. The 3 top right buttons are not working so i cannot do a map eject and throw in my 7.1 either. Is there a way to get the disk out or am i doing something wrong?
Muvh thanks in advance
Fazoolry
Fazoolry
Trouble Maker
On the blank screen where it tells you that there's no nav Disc and you must bring it back to the dealer, and some japanese writting. Use your finger and tap the upper right hand corner twice. Your disc should now eject.
If it doesnt work, try Tapping upper right corner once and bottom right corner once.
Hope you get that damm SOB hybrid disc out.
Worked like a charm.. Now what did I do wrong to not get the hybrid disk to work is the question now. I copied the entire 7.1 disk into a folder on my HD, then just replaced that 1 file. LexusGS3, did you ever get it to work? I mean alot of people with the new gen5 navs seem to be able to have gotten it to work, I really don't care about pressing some accept screen to have over-ride w/ new maps
fazooley
fazooley
fazooley
fazooley
fazooley
fazooley
