Electronic keys won't work
Old 02-20-08, 05:08 PM
ericinkc
ericinkc's Avatar
Default Electronic keys won't work
This is probably a dumb question and an easy fix but for one reason or another the electronic keys aren't working. The batteries aren't dead, when I push the lock or unlock button the red led on the key light up but nothing happens to the car. The car doors don't lock or unlock.
When I get into the car, nothing works. The seat doesn't adjust, the door locks won't work and the engine light button is green.
I've tried pressing the break and pushing the engine start button but nothing happens. I've tried holding the key up to the button and nothing happens. Pretty much nothing happens. Can't get the key to do anything.
Anyone else had this experience and if so how is it resolved?
Thx,
Eric
Old 02-20-08, 06:23 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
when you press on the start the screen doesn't even say "key not detected"?
if so, something is wrong with your car, not the key, especially when seats, etc.. are not working. some major fuse blew out?
Old 02-20-08, 06:55 PM
ericinkc
ericinkc's Avatar
I'm starting to think the battery must be dead. The only thing that doesnt make sense is the start engine button has a green light. Other than that absolutely nothing works in the vehicle. I can't believe they didn't put a manual key start as well as the electronic start. I've had lots of issues with this car.
Thx,
Eric
Old 02-20-08, 07:15 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
that's why i said might be fuse. if battery is completely dead, you shouldn't see light
and i think you have some bad logic. what does that have to do with mechanical key to start the car?! if the car battery is out, i can care less if you have start button or mechanical key, you can't start the car either way.
and even in the case of battery in the remote is out, there is a way still for you to start the car (it's explained clearly in the manual). but this case doesn't apply to you at all anyway
Old 02-20-08, 07:22 PM
The G Man
The G Man's Avatar
Does the door lock button work on the door?
Old 02-20-08, 07:25 PM
ericinkc
ericinkc's Avatar
the difference with a manual turnover is that I would be able to hear the ignition clicking and would be able to diagnose the issue as a battery issue. With the electronic start, it is more difficult to diagnose. Not knowing if it is a key issue, a start button issue or perhaps something else.
I did hold the key up to the start button and this did not work. I'm going to try and jump it tomorrow morning. I am unaware of any lights or other accessories being left on so if jumping doesnt work I'll be calling the lexus dealer.
Old 02-20-08, 07:26 PM
ericinkc
ericinkc's Avatar
no, I have to manually lock the doors.
Old 02-20-08, 07:32 PM
The G Man
The G Man's Avatar
If your lock switch on the door dont work and you have the green light, I dont think its your battery. Did you try checking the battery with a volt meter?
Old 02-20-08, 07:35 PM
ericinkc
ericinkc's Avatar
not yet, was just going to fire up the jumpers tomorrow morning to see if I get any response.
Old 02-20-08, 07:44 PM
The G Man
The G Man's Avatar
How about your map lights, do they work?
Old 02-20-08, 07:52 PM
ericinkc
ericinkc's Avatar
nope, nothing works. I've pushed every button tried every switch and the only thing that's on is the green light on the start engine button.
Its baffling to say the least.
Old 02-20-08, 07:57 PM
The G Man
The G Man's Avatar
Hummm maybe the green light has back up power, just a wild guess, If thats the case, give it a jump and see what happens, cant hurt anything. Please keep us posted.
Good Luck
Old 02-20-08, 08:15 PM
ericinkc
ericinkc's Avatar
Will do, thanks for everyones input. If anyone else has any ideas in the meanwhile I'm all ears.
Old 02-20-08, 10:36 PM
ek9vboi
ek9vboi's Avatar
call Lexus road support or w/e its called. 24/7. lol!!!
Old 02-20-08, 11:58 PM
rominl
exclusive matchup
Senior Moderator
rominl's Avatar
seriously... if nothing in the car works (let alone starting the car), it can't be the key remote problem.
Quick Reply: Electronic keys won't work
