Vibration in rear when applying brakes
Guys,
I have an 07 GS350 with just under 25,000 miles. Lately I have noticed, when drivng on the freeway, a vibration in the rear when the brakes are applied. Usually this would be warped rotors...but after just 25k??? This is my wifes car that I rarely drive and I know she does not ride the brakes hard. Do you think the dealer will take care of it? I Also have a VERY LOUD squeel from the front brakes. I have had the pads changed to the low dust version. Anyone had any luck or these above issues yet?
Thanks,
Bryan
Thanks,
Bryan
vibration only when brakes are applied right? first sign points to warped rotors.
warped rotors can happen anytime, especially early when the pads/rotors weren't properly bedded in.
when you changed to the low dust pads, did you change the rotors as well? and at what miles?
I assume you got it done under the TSIB? low dusts pads are more prone to squealing, just the simple facts of life due to pads construction, they should've warned you for that.
I had the low dust pads put on at around 15,000. No they did not replace the rotors. The Squeel has just showed up in the past 2,000 miles. I think I would rather have dirty wheels rather than the Squeel. It sucks to drive up in a GS and then SQUEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEL! At least the dirty wheels don't draw so much attention.
Do you know how the dealers will deal with the squeel and vibration issue? Are they cool about out it or do they typically say "Sorry...not covered"?
Thanks for the feedback,
Bryan
Bryan
if the pads squeal loud, maybe they were not bedded to the rotors correctly. go back and talk to them (but you have driven it for 10k miles...). thing is you didn't have that problem until they put in new pads, so ask them why
the rear, check, maybe the rotors are warped
I think some of the dealer's arrangement with these TSIB pads is that if you don't like the new pads, they will swap it back for you, but you have to pay for the labor.
However, if you truly enjoy the new dustless pads, there are things you can do to eliminate the vibration of the pads (reason for the squeal)
resurface, anti squeak compound...etc
go to the dealer and complain first, doesn't hurt to ask.
Bryan
Bryan
Brian, I just dealt with this issue a week ago. After driving about 5k miles with the low-dust pads, the squealing began. It was sporadic at first so I just let it go, but it became constant - and loud. They didn't do my rotors when they put the pads on. Anyway I took it to the dealer and was told that they could do my rotors but the low dust pads would eventually squeal again, or they could put original pads back on and there would most likely be no squeal - just a lot of dust. I decided to have the original pads put back on. The brakes are absolutely silent and quite honestly, feel a lot better than they did with the low-dust pads. I'll just have to do the maintenance. The really loud squealing was embarrassing.
sometimes the squealing can come from glazed rotors. You can glaze a rotor with one good insanely hard stop. Does your wife race people when shes going to and from work. I ask bec my wife, who seems pretty calm ,tends to enjoy the occasional speed challenge by young punks in their civics on the freeways. Even if she not a street racer like my wife even a hard emergency stop can glaze a rotor. Good luck.
