Newbie Oil Change Question
hey guys sorry for the newb question but i just couldn't seem to find the answer and i haven't been able to bust out the owners manual.. but does anyone know how much oil our cars take?? i found the diy on how to change the oil and oil filter but it didn't say how much oil to replace the car with... thanks for the help
Assuming you have a '07-08 3GS with the 2GR-FSE V6 engine, officially it takes 6.6 US qts when changed with filter. FWIW, I use 6.5 qts, since its easier to measure .5 than .6 of a qt of oil . . . (always double check oil level on the dipstick)
How do you guys measure 6.6? It'd probably be much easier if I used the 1 quart oil containers. It's a bit tougher for me since I buy the big 5 quart Mobil1 containers. Obviously, if I pour in one container, I'll have to add in an additional "1.6 quarts". Getting to that exact amount is kinda tough so I just check my oil level with the dip stick.
Is there a drawback to using too much oil? Say I accidentally poured in 7 quarts?
Lexus Connoisseur
Yeah the 2GR has large oil capacity. Just ask the 2IS guys.
hey thanks for the information guys.. also i found your write up... i don't know why i couldn't find it before.. weird.. but if anyone else wants to see mool's write up, here it is:
https://www.clublexus.com/forums/sho...d.php?t=338155
thanks again for the info
