DOes anyone have the wire pinouts for the Stock amp
I have an ML 06+ GS amplifier... it doesnt look like I will be able to sell it, so does anyone have the pin out diagram for this amp? I am going to see if I can experiment with this unit.
Also.... does anyone know where I can get a harness for this thing?
Forget Crutchfield, I originally went down that route & was a waste of time and a lot of wasted money if you are looking for a truley superior system than the ML OEM system.
The stock ML system is complex. I have just this week completed integrating the ml system as a DVD interface into an aftermarket system, then using aftermarket head units, amps, speakers etc.
I have rough notes that contain the stock ML pinouts/schematic. I can share it with you if you want, but I need to clean up the documents to be more clear.
If deciding to interface into the existing head unit/amp You will need to tap into the speaker outputs from the ML amp since the amp signal input from the oem head unit is a single digital coax cable.
By the way, dont waste your money on cleansweep. I thried this as the my original design option & was disapointed. (noise, poping, and no equalization)
So, if you would like the pinouts/schematic for the OEM ML system please let me know..
