Xenon Depot Foglight HID Kit Installs???
Anyone install a 9006 xenon depot hid kit in there fog lights? Looking for what everyone did with the in-line fuse set of cables that have 1 line to be grounded, 1 plug into the 9006 plug, 1 plugs into the cabling on the ballast and the last cable is supposed to be installed to the 12v power on the battery??
Anyone out there install this and actually run both red lines to the battery? if not how did you do it?
I ran a wire from the battery (+) toward the front, then across the front of the car (wiring harness above the radiator) and terminated it close to the driver side headlamp. From there I connected the supplied wiring harness.
