Stupid LED parking light
Old 04-13-08, 11:46 AM
ReyRey305
ReyRey305's Avatar
Default Stupid LED parking light
Well I've had these 6LED light parking light bulbs and I tried to install them today... It was fairly easy until the ****N bulb popped out and is now stuck inside my parking lamp housing... I read on this forum someone had the same problem... I tried taking it out with a cloths hanger and sticky tape at the end.. This did not help...
Does anyone know of a better Idea ? Also , If i take it to the dealership do you think they will be able to take it out ?
Old 04-13-08, 12:45 PM
ExTrEmE99
ExTrEmE99's Avatar
Take apart your bumper and shake the LED out? Feel inside the light housing and see if can feel the LED?
BTW: If its loose get some electrical tape and tape it to the wire harness, THe LEDS should fit but i had some problems too, I ended up just buying a new pair of LEDS.
Old 04-13-08, 04:19 PM
07350FROST
07350FROST's Avatar
those LED lights suck IMHO anyway!!! If you get it outta your light assembly, leave em out! there are other options that look really well too.
Old 04-13-08, 04:28 PM
SiccMonkey
SiccMonkey's Avatar
i have used a zip tie with tape on the end to retrive bulbs before, loosely wrap some tape around the end to form a "cup" that you can then try to catch the head of the bulb in. pull the bulb out through the highbeam hole.
Old 04-13-08, 04:50 PM
ReyRey305
ReyRey305's Avatar
Zip tie the same as those plastic wrap ties right ? That sounds like a great idea, thank you very much !!!! I will try it 2morrow
Old 04-13-08, 08:20 PM
kyang91
kyang91's Avatar
wow.....I think if you take it to the dealer they can take it out no problem
Old 04-14-08, 12:01 AM
wikidbwoy
wikidbwoy's Avatar
i had the same problem i just gave up and left it in there. i used one of those tool pick things not sure of the name it opens like a claw when u push on it kind of like those teddy bear games. it would have worked if i could see the bulb.
Old 04-14-08, 12:39 AM
SiccMonkey
SiccMonkey's Avatar
Yep the very same. worked for me, lucky for me it was the passenger side so i removed the airbox and had lots of room to play
Old 04-14-08, 06:24 AM
The G Man
The G Man's Avatar
You can try a shop vac and see if you can suck it out of there if you can some how seal the opening. I would remove the high beam bulb and work from that opening with a cloth hanger 1st since that opening is bigger and lower.
I hear the same story a lot with LEDs. The cheap LED just dont fit as well or cant stand up to the heat, thats why I havent use LED in my parking light yet. PIAA make a good 194 bulb that will fit tight but its not bright enough and its too blue. The tinted bulb I got in there now snaps in and lock in pretty tight and matches the HID pretty well.
Old 04-16-08, 12:20 PM
OutkastGS3
OutkastGS3's Avatar
The contact point of the bulb should be metal. Try to use a strong magnet (pick up at any auto shops) and get it out that way. If the contact point is not metal then I don't know.
Old 04-16-08, 12:25 PM
The G Man
The G Man's Avatar
Those 194 wedge bulbs, unlike other bulbs that have a metal base, only have a thin piece of wire as the contact point, it would be very hard to pick up with a magnet.
Old 04-24-08, 10:03 AM
ReyRey305
ReyRey305's Avatar
Ok, I tried the technique with the tie strap and sticky tape and it worked like a charm the first try... Thank you soo much, I just put in those 4 LED super white and they look pretty cool.. They are brighter than I thought
Old 04-26-08, 12:41 PM
ReyRey305
ReyRey305's Avatar
Here is a pic of the super white LED's I put in.. Now I have to match the HID low beams.. What color bulb do you think will look good with it, 6000k or 8000k ?
Old 04-26-08, 12:59 PM
EyeKutr
EyeKutr's Avatar
why not match the HID with the 194 bulb, much easier, cheaper and better light output in the long run
Old 04-26-08, 01:04 PM
UberNoob
UberNoob's Avatar
yeah its more economical to have the wedge bulbs match the HID lights that is if u are ok with the HID colour
polarg M4/M6 are good wedge bulbs for that purpose
Quick Reply: Stupid LED parking light
