Malfunctioning Rear Park Assists Sensors
I cannot seem to recreate this at the dealer and they said they have not had any complaints about it...
Well during my commute to work, there is one intersection with a red light camera. If I am the first car at the intersection, my front sensors go off. Annoying, but I am guessing it has to do with the camera. I have gotten used to Now it seems when I put the car in reverse the back passenger side sensor goes off. The first couple of times it did this, I got out of my car to check to see if something was on the sensor. Nothing on them, put the car in reverse and it happens again. This happens when it is nice and sunny, no rain or snow.
This does not happen all the time, just enough to cause a little surprise when backing up. Nothing like thinking you are about to back into something you cannot see.
Any ideas on what could cause this? Can the the dealership readjust the sensors?
Stefnee
Stefnee
hmm.....I am not suer what is your problem, I have the same thing happen to me a few times but whenever I go out and wipe the sensor a few times it would not happen again so you might want to try that. In many cases it might just be the dust
Stefnee
Stefnee
Disclaimer.. I'm not recommending 'car abuse'. Having said that, when mine did it... I got out and kicked the bumper a couple of times.. hasn't done it since. That'll teach it!
Interesting...I had my right front sensor malfunction. Initially, it would go CRAZY without any obstacles nearby, and now it is ok, unless there is an obstacle now, and when there is, it is on the red no matter what the distance is...took it in to the dealer, and they are going to replace it...They told me that they tend to malfunction sometimes without any reason sometimes. Now I'm concerned if and when the others will malfunction, and what if my warranty runs out then??? Too much tech is BAD!!! Too many things that can go wrong...It may sound dishonest, but I would kick the sensor with a blunt tool, so that it doesn't look like it was hit...I'm concerned how much it will cost without warranty.
mikevanle
05-01-10 12:23 PM
