Awful brake dust...free brakes!!!
Okay...if your 06 GS is anything like mine was then an hour after a car wash your front rims were black. I just went in for a service and went on a ride with one of the technicians to show him a rattle in the dash. On my walk back in with the tech, I asked him what I can do about the excessive brake dust on my front rims. He told me that he knew for the IS model, if you complain, they replace the pads with the newer low dust pads but wasn't sure about the GS. I went inside and complained and low and behold, an hour later I had brand new pads installed. I've had them for about 2 weeks and there is absolutely no dust at all!!! I highly recommend each of you complain and get your new pads. Let me know if this works at your dealership.
There is a TSIB about this... and they should/WILL replace your brake pads because our GS's have the high friction brake pads which emit more brake dust than normal. They replace your pads with a pad that emits less brake dusts but supposedly it doenst stop as well? I dont know for sure but thats what i read on the TSIB.
so far i've only clipped 3 pedestrians which isn't that bad for 2 weeks, right? actually, the pads seem to be working as good if not better than my originals. highly recommend getting this done. is there a listing of other TSIBs somewhere? also, has anyone located the touchscreen sequence for a new 5.1/7.1 hybrid navigation disk?
My dealer changed the brakes no problem - even installed brand new rotors - the original brakes had 13,000 kilometres on them and the dust was infernal. Now hardly any dust at all and braking seems to be just fine (2007 GS350)
I just called my Dealership I told them I need new pads due to dust and a TSIB I found on the internet and I now have an appointment for Monday morning for a pad exchange on Lexus. They did add that the new pads tend to be more squeaky. Does anyone think that I should put the stocks back on before bringing it to the dealer or will the aftermarket wheels be an issue?
about the wheels, no one know how careful your dealership is. if you are not confident, swap it out first
