View Poll Results: OEM Rear Lip Trunk Spoiler or Aftermarket?
Don't go with rear lip spoiler, it doesn't look good
0%
Voters: 20. You may not vote on this poll
OEM or Aftermarket Rear Lip Trunk Spoiler?
executive matchup
Hey guys:
I'm in the processing of getting a 2008 GS450h, and I'm debating whether I should go with an OEM rear lip trunk spoiler or aftermarket rear lip trunk spoiler (like from Ings, for example). Which one would you choose and why? Thanks for your opinion/help!
executive matchup
According to my auto broker, it seems that a special order might be necessary to get APSSS, MK audio, and Navi in Mercury metallic (which are the options I want) - APSSS does not seem to come in large numbers. If that is the case, the 450h I order may not come with a rear lip trunk spoiler (unless I specify). Hence the reason for my post.
executive matchup
Wow, overwhelming result! I did not expect this, I thought it would be closer like 60-40 in favor of OEM. Looks like the choice is clear - OEM it is! Thanks guys for voting, I'm gonna tell my broker to make sure the OEM lip is included.
the artisan spirits spoiler isn't bad. nice size.
To the OP:
You have many options to go with here and I would wait to see what you really want and not what others have! OEM is good and looks good with out a doubt. Aftermarket will look better IMO and save you the $$ the stealership wants to charge you for that. You can also get that same spoiler for a fraction of the cost from one of our vendors if OEM is what will make you happy. I have installed them on many cars and its really easy if you are up for a DIY? Either way you go fit and finish will be all the same. Its all about looks and one will be the same as the rest and the other will be more unique
Good luck in your decision!
