Synthetic Oil users
Old 05-26-08, 12:07 PM
mcamson
mcamson's Avatar
Default Synthetic Oil users
For those of you that use synthetic oil, how often do you change your oil?
Old 05-26-08, 12:12 PM
jdmJZA70
jdmJZA70's Avatar
i use mobile 1 5w30 with toyota oil filter and i change my oil every 3k...but then again its easy for me since i work at a toyota dealership...if i didnt work there i would probably wait till ever 5k to change my oil...
Old 05-26-08, 01:52 PM
valgs350
valgs350's Avatar
Every 5k!!!!
I also re-clean the K&N and MAF sensor!!!
Old 05-26-08, 02:30 PM
dandd2
dandd2's Avatar
i believe syntheic oil is required in for this vehicle..
maybe im incorrect.
could someone please verify?
regardless i use mobil 1 extended performance
they claim you can drive up to 15k or up to a year
this they claim but if you blow your engine they will say
"you should've follwed your owners manual"
Old 05-26-08, 05:58 PM
ISFTwins
ISFTwins's Avatar
They come from the factory with a synthetic blend.
Old 05-26-08, 08:18 PM
steviej
steviej's Avatar
I change with Mobil 1 synthetic (not the Extended Performance formula) every 5k miles.
steviej
Old 05-26-08, 08:28 PM
**FL Lex**
**FL Lex**'s Avatar
Every 5K like clockwork
Old 05-26-08, 11:11 PM
EyeKutr
EyeKutr's Avatar
To the question above, Engine oil does not require synthetic, I use Mobil 1 5-30 every 5k
Old 05-27-08, 05:27 AM
The G Man
The G Man's Avatar
The GS come from the factory with a synthetic blend but it doesnt require full synthetic or synthetic blend? I am confuse.
Old 05-27-08, 06:50 AM
ripitup
ripitup's Avatar
Default mobil one
I change my oil every 10,000 miles in my 2001 LS430 . I have had my oil analiyzed once at 7500 miles and again at 10,000 (80% oil life left, but containaments were getting to the point they recomended changing it before 12,000 miles. Corvettes factory filled mobil one change every 15,000 .Porsche ,(check thier website) mobil one every 20,000 miles. You are throwing money away at 3k or 5k. The LS460 comes with regular motor oil from the factory 0-20 weight. They do not recomend synthetic, I asked why? The Lexus rep said they do not see the customer often enough for other maintence!!!
Old 05-27-08, 07:17 AM
Lexaholic
Lexaholic's Avatar
Change every 7.5K
Old 05-27-08, 07:31 AM
Rob Daddy
Rob Daddy's Avatar
i have a 2nd gen GS and change mine every 3000 with a Toyota filter
i guess after reading this i guess i could go longer
Old 05-27-08, 02:06 PM
Jace7
Jace7's Avatar
I changed my 450h every 8-10K with mobile 1 full synthetic when I still had it.
Now I change our GX every 8-10K with mobile 1, and our new addition to the family cayanne gts every 10K.
Old 05-27-08, 07:06 PM
Bavaria
Bavaria's Avatar
I agree synthetic oil will last longer, but will the oil filter go 7-10k without breaking down?
Old 05-28-08, 04:15 AM
NavyDoc333
NavyDoc333's Avatar
Ditto... Pennzoil Platinum every 5k
Quick Reply: Synthetic Oil users
