Keyless Fob, Unlocking doors
to all very valid points!
I will try that setting change in the manual.... have you seen the manual....its like a million pages...holy crap!
thanks everyone!
thanks everyone!
I would assume that the smart key/fob for GS350 is the same as the GS300 smart fob.
Page 23 of my manual (2006 GS300) gives instructions on how to change the door unlocking setting on my smart fob. You can reprogram it to unlock all doors when the driver grabs the driver's door handle.
CHANGING THE DOORS TO BE UNLOCKED
(Picture didn't copy over)
When you push the “LOCK” button together with the
“UNLOCK”, “TRUNK” or “PANIC” button on the electronic
key for about 5 seconds with the engine switch off, you
can change the settings for door unlocking.
The settings will change in the following order:
1. Unlocking driver’s door
2. Unlocking the side doors
3. Unlocking a single door
4. Unlocking all the doors
After setting, a tone sounds and the multi-information display
shows which setting is selected. Outside the vehicle, one beep
sounds when the single door is set to be unlocked, 2 beeps
sound when all the doors are set, 3 beeps sound when the
driver’s door is set, and 4 beeps sound when side doors are
set.
steviej
set.
steviej
Speaking of the key fob. Why is it that when I touch the door handle to unlock the door there are 2 beep and other times there are 4 beep. What is the difference?
