where 2 buy 65mm oil cap
Where can I buy the 65mm oil cap??? I will purchase online as a last resort but I'm wondering if I can buy this at a pep boys, Kragen, etc.
Thanks.
Thanks.
Its not 65mm, its actually 64mm, if u use the 65mm (where u can buy anywhere) it will skip and get stuck....i used a 65 and a thin rag inside to remove the filter and it was still a ***** w/ skipping and got stuck like crazy...so the actual size is 64mm....At the prius forum they said 63mm but thats too small, i actually measured it w/ calipers and 64mm is the closest...The funny thing is TOYOTA says its 65mm....WRONG!!!!![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Not sure where to buy, but i do need one, if u order from lexus/toyota they will send u a 65mm...typical toyota stupidity
myes350
ES - 5th Gen (2007-2012)
02-01-08 11:18 PM
