GS460 / GS350 Options Difference?
Is there anything available for the GS460 that's not available for the GS350? Other than the 8 speed transmission and V8, is anything else different? Being that the 0-60 and 1/4 mile times are so close (within like 3 tenths of a second), it seems there's no logical reason (with gas prices as high as they are) to opt for the v8 - for almost $10,000.00 more. Is there something I'm missing? Is it THAT much quieter or smoother?
Thanks....
Thanks....
There's an active stabilizer bar system available for the GS460 that isn't available on the GS350.
http://www.lexus.com/models/GS/features/pricing.html
Okay. So I haven't seen anyone write anything (at least here) yet about the v8 being more quiet, smooth or refined.. That's good..
Now about the leather.. I'm a nut when it comes to nice, soft leather. However, I've tried to tell the difference between the semi-aniline and non-semi-aniline leather in a 2005 LS430. I couldn't tell.. I know one had it and the other didn't. I "THINK" the leather of the semi-aniline MIGHT have been the slightest touch softer - but I kept going from car to car to see if it was just me or what.. So if there's any difference between semi-aniline and non semi-aniline - the difference is so tiny that I can hardly see calling it "much better".
On the other hand, if there's something else that makes it that much better, let me know. Maybe I'm not understanding something.. Again, I'm crazy about the leather in cars - so I figured if anyone would notice a major difference in feel, it would be me... I actually buy vehicles based on the leather seats. I know, it's insane. And it's even more insane that I'm driving an Escalade with the leather on its seats..
Aniline leather is simply dyed with pigment added for consistency in color, and shows imperfections in the hide, will fade out eventually in the sun, and wears fairly easily - not a good leather for cars, to say the least.
Semi-aniline leather is very lightly clearcoated, and is typically softer than typical coated leather. It is subject to wear quicker and easier than coasted leather.
Protected aniline leather (what most of us actually have in cars) are clearcoated, and are the best for wear, color consistency, etc.
For those of you buying expensive leather conditioners, you're wasting your time if you have protected aniline leather. I use Zaino leather products regardless because I like the scent, but protected leather has a poly clearcoat on it, and you can protect it with the same stuff you use on your dash (really!).
Leather care products WILL NOT soak into clearcoated leather, so if you leave a leather care product on your clearcoated leather, buff it off, and then convince yourself that the seat "really soaked that up", you're suffering from a placebo effect.
Again,I still use Zaino conditioner because I like the UV protection,matte finish and great leather scent.
Okay. As far as I'm concerned, the leather in the GS350 is just as good as the leather in the 05 LS430 that I drove for about a year.. To me, that's good enough..
Now.. I see 0-60 and the 1/4 mile are just about the same in both the V6 and V8 GS.. I'm guessing the biggest difference in power will be more noticeable from 100 mph and on.. Correct?
ok... let's list out the difference
semi-aniline leather, AVS (although available on GS350), VGRS, V8 VVT-iE (VVT-i on 350), 8sp, 18" standard, ECB (electronic controlled braking, brake by wire) and APSSS
exclusive matchup
i thought you didn't need words on the powertrain. but since you ask, yes, the gs460 will be a lot quieter, smoother, and more seamless shifting. i had ls460l before, so i know the difference first hand.
about the leather, it might be subjective, but to me the semi-aniline leather is a lot better than the normal leather. significantly softer
I haven't driven a GS460, but it's bound to be quieter and smoother than the GS350. The GS460 has the LS' V8 and 8 speed auto, plus the direct injection in the engine in the GS350 has been reported to be quite loud.
GS350's engine is very refined, I am sure it's very smooth and quiet. I wonder if any magazines has data on GS350 and GS460's interior noise measurement.
I found the below data (GS350) from a Taiwanese website, but they are self measurement:
Door closed>Idle>lowest air-con on 28.5 dB -> 39 dB -> 45 dB
What made you switch from an LS460L to a GS460? Would you mind giving me a comparison of both? Unless you've already posted it somewhere - than can you give me the link? I'm really curious about the difference in ride and quiet within the interior between both models.
I'm guessing the GS is a much more "fun" vehicle to drive.. Any differences that you can tell me between the two would be greatly appreciated. Of course, besides the obvious.
Thank you...
Thank you...
