TSIB's ?
TSIB's ?
I have a 06 300AWD and have not had any real problems, other than the rattles, squeeks etc. I am coming up on the 40k service. My question is, how can I find out about any TSIB's for my car? Is the brake pad issue relevent to the 06? How about the dash rattles? Would you ask to have it fixed in the summer when it is pretty quiet? Finally, do you think the dealerships treat these issues differently for drivers who lease their cars? I have about 8 more months on my lease and am considering buying the car at the end and would like to get any TSIB's done prior to. Thanks to all for any thoughts.
Mark
Mark
there are sites like alldata that lists out all the recalls and TSIB for all manufacturers, but it costs money
all of the issues you've mentioned have been discussed before and TSIB posted, so just do a search, but those are pretty common issues, i wouldn't worry about it unless the dealership thinks your problems are normal.
Just tell your dealer you are considering buying the car if they can fix the rattles. The dealer cannot fix the rattle if they cannot hear it, more than likely, you will have to wait til winter. There is a TSB for the windshield ticking noise for the 06 and thats it, no TSB for the dashboard squeaking problem, but the dealers are well aware of that problem.
here's you list. Mind you, most of them are not serious and are just new instructions to the mechanics.
TSB Number & Issue Date TSB Title
AC003-07 DEC 07 A/C - Water on Front/Rear Carpets
PG008-07 NOV 07 Vehicle - Replacement Certification Label Information
PG007-07 NOV 07 Vehicle - Replacement VIN Plate Information
SS006-07 AUG 07 Electrical - Absorbed Glass Mat (AGM Battery Information
SS005-07 AUG 07 Restraints - SRS Component Disposal
EG016-07 JUL 07 Engine - Brief Rattle/Knock On Cold Start Up
TC008-07 JUN 07 A/T - 'World Standard' Fluid Information
EG015-07 JUN 07 Engine Controls - Bank 1/Bank 2 O2 Sensor Identification
AC001-07 JUN 07 A/C - Cabin Filter Replacement Procedure
NV007-07 JUN 07 Interior - Inside Mirror Vibrates
BO006R-06 MAY 07 Body - Rear Power Sunshade Won't Open Fully
EG008-07 MAR 07 Engine Controls - MIL ON/DTC P0172/P0175 Set
EG007-07 MAR 07 Engine Controls - MIL ON/Multiple DTC's Set
ST004R-01 MAR 07 Steering - Vehicle Pulling, Manual Supplement
PG001-07 MAR 07 Tire Monitor System - Diagnostic Tips
EG003-07 MAR 07 Cooling System - Leaks From Water Outlet Assembly
EL001R-06 MAR 07 Smart Key(R) - Repair Manual Supplement
TC002-07 MAR 07 Drivetrain - Driveshaft Replacement Precautions
SS002-07 MAR 07 Engine Controls - Techstream(R) ECU Flash Reprogramming
EG001-07 FEB 07 Engine - Timing Cover/Camshaft Housing OIl Leaks
TC009R-06 FEB 07 A/T - Identification/Serial Number Locations
EL002-07 FEB 07 Air Bag System - Repair Manual Supplement
EL016-06 DEC 06 Starting System - Vehicle Start After Battery Depletion
EL015-06 DEC 06 'Smart Key' (R) - Specifications
NV005-06 DEC 06 Body - Upper/Lower Windshield Ticking Noise
PG001R-06 NOV 06 Battery Maintenance for In-Stock Vehicles
SU001-06 OCT 06 Suspension - Shock Absorber Replacement Criteria
TC010-06 OCT 06 A/T - Reman A/T Serial Number Location
NV004-06 SEP 06 Interior - Rattle From Instrument Panel
EG014-06 JUN 06 Emissions - MIL ON/DTC's P043E/P043F/P2401/P2402/P2419
AC002-06 JUN 06 A/C - Intermittent Odors
AU001R-05 JUN 06 Audio System - Dash Speaker Connector Rattles
NV001-06 MAY 06 Interior - Front Seat Squeaking Noise
EG011-06 MAY 06 Exhaust System - Excessive Sulfur Odors
AX001-06 MAY 06 Audio System - SIRIUS(R) Radio Antenna Separation
AU001-06 APR 06 Audio System - Quick Reference Troubleshooting Guide
EG006-06 MAR 06 Engine Lubrication - ILSAC GF-4 Oil Recommendation
BO002R-06 MAR 06 Body/Lighting - Headlamp Support Bracket Installation
PD023-06 MAR 06 Parking Assist System - Initialization Procedure
EG001R-06 JAN 06 Engine - ILSAC GF-4 Engine Oil Standard
BO001-06 JAN 06 Body - Trunk Will Not Close
SS003-05 NOV 05 Audio System - CD Player Skip Verification
EG020-05 NOV 05 Engine Controls - MIL ON/DTC's P0171/P0174/P02195/P02197
BO012-05 NOV 05 Interior/SRS - Seat Cover Replacement Recommendations
BO010-05 OCT 05 Restraints - Seat Belt Extenders Available
CRIB150 OCT 05 Paint - Paint Codes
BO008-05 SEP 05 Body - Left Rear Door Lock Difficult to Operate
NV002-05 SEP 05 Body - Creaking Noise from Back Glass Area
SS005R-01 AUG 05 Antitheft - Diagnostic Tester Immobilizer Function
BO007-05 AUG 05 Interior - Glove Box Doesn't Open
BO006-05 AUG 05 Interior/Lighting - Dome Lamp Comes Loose
TC003-05 AUG 05 A/T - A760H Solenoid Identification
PG007-05 AUG 05 Tire Pressure Monitor - Sensor Registration/Initializing
PG005-05 JUL 05 Tire Monitor System - Tire Dismounting Procedures
BO004-05 JUL 05 Wipers/Washers - Wiper Blade Cleaning/Maintenance
EG012R-04 JUN 05 Engine Controls - Entering VIN After PCM Replacement
SU001-05 JUN 05 Suspension - Creaking Noise From Front Suspension
EL006-05 MAY 05 Electrical - Vehicle Start After Battery Depletion
BO003-05 APR 05 Restraints - Seat Belt Extender Availability
PD008-05 FEB 05 Tire Pressure Monitor - Sensor Activation
PD007-05 JAN 05 Body - Power Window Initialization Procedure
PD003-05 JAN 05 Body - Sliding Roof Initialization Procedure
PD004-05 JAN 05 Interior - Driver's Head Restraint Initialization
PD001-05 JAN 05 Instruments - Compass Calibration Procedure
steviej
Automotive Recall and Technical Service Bulletin Titles for 2006 Lexus GS 300 AWD V6-3.0L (3GR-FSE).
steviej
dchan865
RX - 4th Gen (2016-2022)
07-15-18 03:42 AM
calvin2376
04-04-11 10:01 AM
tfz_hebe89
02-23-08 03:32 PM
