Good palces to pick up a K&N intake for the 3GS
I am going to be getting a typhoon intake to go with the coilovers, and I ws wondering where you guys would rec buying the intake from???
I think the intake will get rid of the numbing element in the intake. I want this car to wake up alittle.
I like the fact that the piping is a plastic material. The fujita is a metalic material. The metal will retain more heat and therefore increase the temp of the intake air. Plus the K&N unit has a heat shield. The fujita doesnt. so you will be drawing hot air from the engine area directly into the intake. The HKS intake is probably the best in terms of overall design, bbec the filter is encased in a box. I just dont think its worth double the price ($460). I also like the fact that k&n has dyno charts that verify the hp gains. Their intake kicks up the hp all the way accross the rpm range and will make the car sound like it has some *****
most likely we have all lost some hp secondary to the big *** staggered wheels we all love and use. More unsprung weight = less whp. so we can at least get some of that back by using the intake system. The dyno graph will show hp reading for a stock car generally. with the wheels ( or larger brakes for that matter) you are always going to lose some hp
