53K Miles and still have original brakes...
Had the dealer check them and they said that there are 6mm remaining on rear and 4mm on front - so they don't need to be replaced yet. I do lots of highway driving so that is why I have not had to replace them with this many miles...how many others are out there like me?
Mine where done just this past weekend. Had 26k on them. Mostly city driving. They were replaced for free under the excessive brake dust TSB. The dealer told me the pads had about 3mm worth of material left, and that at 2mm, grinding of the rotor begins.
Lexus Connoisseur
Lexus brakes do well with freeway/long distance driving. On my previous 04 IS300, I put about 95k on the front pads. The rear pads went out first at 80k. The rotors were in great condition and were turned. There's no need to change out rotors unless they're warped.
I learned that trick to, I let them bring it up, i take it in and say the brakes dust to much and then next time I say it squeaks to much and if you use different dealers...lol
Just a funny neat trick that costs lexus money!
Lexus Connoisseur
Doesn't quite work that way because all Lexus service departments can see your service history. It will show if a TSIB has been performed or not.
Luck!
I have to change my brakes cause of all the track days that I do, see how long this trick lasts!
you won't get away with the squeaky excuse, unless it really squeaks.
they will test drive it to see if it is true.
