Anyone else with IPHONE 3G?
Old 07-28-08 | 10:45 PM
bobbyt01nc's Avatar
bobbyt01nc
Originally Posted by Tego1090
My BT will only ring if I use the Lexus unit to dial. If I use the iPhone to dial, then you only hear sound when "Connection" shows up on the screen. I just use the head unit to dial now....
sorry in advance for the question and i probably should know this, but how do you dial from the headunit...just punch in the numbers or did you download your numbers. I have not done that b/c i thought it would take too long to key in all numbers
I have always done it from the phone itself...
Old 08-11-08 | 09:40 PM
asem111's Avatar
asem111
i have the 3G iphone, paired with a 2006 GS3, and have similar issues. I too can't hear the rings when dialing out.
I have another related question/issue. When I dial out from my phone while in the car, I get 3 audio options displayed on the phone: use the phone as the source, use speakerphone on the phone, or use the car audio via bluetooth. When I select the phone option, so that i use the phone to speak into and hear from, the bluetooth in the car is engaged, and displays the bluetooth screen, muting the radio/CD.
My question is, if I selected the source of the audio to be my phone, why does the car still activate the bluetooth screen on the car? Its annoying cause the radio/Cd switches off while the call is being made.
is that a lexus issue, or a iphone issue?
Old 08-12-08 | 05:20 AM
ecount00's Avatar
ecount00
i think it's a quirk with the iphone because of the oneclick source choice you describe. the stereo just knows it's linked and can tell the phone is in use so it mutes the music because it has a simple brain: phone in use, voice on the way, kill sound. the fact that you choose a different 'output' for the sound rather than the car is an iphone thing. I doubt that apple or lexus will agree it's an 'issue'.
my 3g works the same way with my GS. doesnt bother me, i'd turn down the sound anyway even to make a call via the phone. personal preference for me.
Old 08-12-08 | 08:08 AM
ted5469's Avatar
ted5469
How do you connect the iphone BT to the car. I have a 07 GS350 and when i try to pair the phone with the car it tells me unable to pair.
Old 08-12-08 | 08:10 AM
borg1of2's Avatar
borg1of2
CL Folding 25,000
Originally Posted by Avid1
When I purchased my car at Lexus Santa Monica, they had an onsite Bluetooth specialist who helped me pair my phone and transfer phone numbers. You might want to check to see if your dealership has a rep like this who can assist you.
I am curious how the rep transfered contacts from your iPhone to your Lexus? I have an original iPhone with an 07 GS450h and was told that the phone can't do bluetooth transfer of contacts, which is what the Lexus is looking for.
Old 08-16-08 | 08:51 PM
jannie02's Avatar
jannie02
Did you every get an answer to your question? I have the same problem. I can not connect my Iphone 3G to my Lexus GS350. Can anyone help?
Old 08-17-08 | 06:29 PM
ecount00's Avatar
ecount00
I have an iphone 3G and had no trouble pairing it to my 06 GS. on the iphone, settings, general there is a screen to turn on bluetooth, and the hands free shows up there when i go through the add a phone sequence on the car system. i press the hands free entry on the iphone/settings/bluetoosh screen after it shows up and a keyboard pops up to enter the pass code. have done it several times.
Old 08-18-08 | 07:54 PM
Tego1090's Avatar
Tego1090
I just disconnect the iPhone bluetooth when I only want to use the actual iPhone.
Old 12-29-08 | 05:29 PM
macsanchez's Avatar
macsanchez
does anyone have a solution to the loud buzz on outgoing calls on the iphone. Pretty annoying. this did not happen when I ade outgoing calls on my blackberry.
Any help would be much appreciated.
thanks
Old 12-29-08 | 11:35 PM
thomastan's Avatar
thomastan
I have same problems...mine is 2006 GS430 with Iphone3G...so annoying !!!
Old 12-30-08 | 06:29 AM
AWDMan's Avatar
AWDMan
Originally Posted by bobbyt01nc
a girl at the AT&T store made a decent point...she said the IPHONE has a new version of bluetooth built in (V2) and since I have a 2006 model maybe the BT installed was a older version...where as the 07 GS's have all the upgrades and maybe that's why I am the only one having issues.
Does this sound right? I may be SOL...
Any Lexus techs know of anyway to update that software for BT if there is such a thing?
I have an '07 GS350 AWD and have had no problems whatsoever. Everything works perfectly.
Old 12-30-08 | 07:18 AM
IXI187IXI's Avatar
IXI187IXI
i have the same problem where the bt only picks up when the other party answers the phone or the voicemail picks up. usually if i make a call from my phone, i always hit the iphone button on the screen instead of the bt this way i can hear the phone ring.
Old 12-30-08 | 07:30 AM
scottgs's Avatar
scottgs
Does anyone have problems with it connecting to the car when you dont want it to?? Like if my car is running or on and I am in the house or around it, it will connect to the car when making a call. So I am saying hello hello and no one is there, until I change it back to the phone connection. It has happen numerous times but only when the car is on.
Old 12-31-08 | 07:30 AM
tunedis95's Avatar
tunedis95
I have an 06 gs430 which is synced with a 3g as well. Everything works great. I have that same deal about making outgoing phone calls.No ringing just a straight answer if they pick up.. Kinda annoying but figures it's alright.
Old 05-16-09 | 03:59 PM
VIPNiSS's Avatar
VIPNiSS
I have the same problem. It doesn't ring when dialing out from phone. I hear the radio and when the other party picks up is when its switches over.. annoying.,
