Airconditioning leak?
This morning I noticed pool of water inside my car, at the front and rear passenger foot well except for the driver side. The fluid is clear and odorless. Any idea how the water found its way inside the car? Have anyone had the same issue before?
The dealership said, they'll need 2-3 days to find out the root cause as they have to remove the interior fittings and dashboard. I hate the sound of it. I thought it should be an easy fix?
Happened a friends es. Pull back the carpet on the passenger side and there is a black tube on the left. See if it came out of the hole that leads to the floor of the car. This is the drainage from the ac unit in the dash. I just put the tube back in the hole and put some glue around it and never had a problem again
Jcham
09-06-09 05:20 PM
