10,000 mile service help?
I first got a quote from the dealer for $120 for the 10k mile service, few minutes later I get a different quote from the SAME dealer saying its $190 for the 10k mile service. They told me they have to drain the plug gasket thats why its so expensive and they use synthetic oil. Sounds a little fishy to me.
How much have you guys paid for your 10k mile service? Does 190 sound about right? I read the checklist for a 10k mile service, some of the things included like check fluids levels, check tire pressure....all these little things up to $190?
I wouldn't bother going to the dealer at 10K miles.
Change your oil and maybe check your cabin filter.
The drain plug gasket is about a dollar.
If you want to go to the dealer just tell them to change your oil and filter.Nothing else.
They will get big bucks for a synthetic oil change.
I do my own with Amsoil 0w30.
My GS won't see the dealer even for that freebie 5K oil change.Only warranty issue will bring my GS into the dealer.
At a $110 an hour, thats only 1 hour worth of work. I dont do those 10K 0r whatever service, its a waste of money. Just change the fluids, filter and belts and you will be fine. If you know how to check tire pressure, you have just save yourself $20
What plug gasket are they talking about and why isnt it under warranty.
Its funny because, the master technician at the dealer told me lexus doenst use synthetic oil and he wouldnt reccomend it because its not worth the money.
I believe in synthetic oil.
I change my oil once a year and prefer Amsoil 0w30.Mobil 1,Pensoil Platinum etc is fine too.
My GS only does about 6K miles a year so it sits.
Oil stays oil but Dino oil additives deplete over a course of say 6 months even sitting.
Synthetic hold additives longer.
The wife's RX does about 12K a year.It's a lease and I'll change the oil and filter once a year with Amsoil 0w30 after the frieebie at 5K.
I don't like bringing my cars into the dealer.
I don't care with the wife's lease but am very **** retentive with my car.
Lexus Connoisseur
Synthetic vs. Conventional is an age old battle. Lexus is rated #1 in vehicle dependability by J.D. Power year after year. This is without the help of synthetics btw.
Look at it this way, if Toyota/Lexus recommended it, it would be a requirement in all their vehicles....especially the IS-F. When have you seen a Toyota/Lexus motor breakdown from poor lubrication? It's pretty unheard of. If anything, Toyota is legendary for engineering motors that go well into the 300k mile range without any problems other than the regular maintenance. If you follow the recommended service intervals that Lexus goes by which is every 5k, you will not encounter problems. I've had several Lexus and Toyota vehicles which i've pushed well over 100k with no problems following the suggested factory guideline for service intervals as well as using regular multiweight conventional motor oil and a Toyota filter.
However there are advantages to using synthetics.
Longer change intervals,easier winter startups and in my case,a car that doesn't do many miles in a year.
Toyota engines also had oil sludge engine issues,so the company isn't perfect and quality has been going down.
Ok we're getting off topic here, I didnt ask is synthetic worth it. BMW would disagree with the conventional because they change oil ever 10k miles not every 5k . I appreciate the comments about synthetic vs conventional.
My question is is $190 normal for the 10k mile service? Is the service worth it?
Actually,BMW goes 15K on oil change and filter.
Costs vary from dealer to dealer but $190 seems really high for an oil change and check this and that.
Just get a price on an oil change alone.
Lexus Connoisseur
There are advantages and disadvantages to anything. I wouldn't go with longer oil change intervals just because you can do so with synthetics. Lexus did not spend millions of dollars to engineer and print a suggested guide for maintenance in your owners manual for decoration. Their engineers have spent countless hours of testing to ensure longevity and with the use of conventional oil. Easier winter startups can be achieved with going with a different weight of motor oil, doesn't matter if it's conventional or synthetic. 5w-30 is what comes from the factory, but 5w-20 will work fine as suggested by the factory.
Lexus Connoisseur
Thank you for the comments. Seems seems like a re-occuring thing, You like to disagree or correct everything I say. Anyways thanks to all who posted, I will see if i can get a quote or just get the oil change done.
It's no myth synthetics can go twice and more mileage than dino oil.The choice is available for what ever people want to use..
