Automatic door locking and unlocking with Shift position or vehicle speed?
I have the 2006 GS430. Whenever I place my car in park, I'd like the doors to unlock and according to the manual (see below instructions direct from manual) you can program them to do so. But, I am unable to program.. Nothing happens and I am definitely following the instructions corrrectly. Is there another method to program? I stopped by the lexus dealership on saturday and the techs were gone but someone from the service dept told me the only way that he knew of was for the tech to hook up his computer and program it, then I asked him why it was documented in the owners manual that is was programmable and he couldn't answer. Has anyone tried this or had success with the manuals instructions or know of another way ? Thanks.
(INSTRUCTIONS FROM MANUAL)
AUTOMATIC DOOR UNLOCKING
You can select the following functions:
Unlocking linked with the engine switch
All doors are automatically unlocked when the the driver’s door
is opened within 10 seconds after the engine switch is selected
in “ACC” or “OFF” mode.
Unlocking linked with the shift position
All doors are automatically unlocked when the selector lever
is moved to “P” position.
You can set or cancel the automatic unlocking functions:
Be sure to apply the parking brake when performing the
following operations.
To select the unlocking linked with the engine switch:
1. Close all doors and select the engine switch in “IG-ON”
mode.
2. Shift the selector lever from “P” to the “N” position.
3. Within 10 seconds of selecting the engine switch in “IG-ON”
mode, press and hold the driver’s side power door lock switch
in the unlock position for 5 seconds and then release.
The doors will be locked and unlocked to indicate that the
function is set.
To cancel the function, do the above operation again.
To select the unlocking linked with the shift position:
mode.
2. Shift the selector lever to the “P” position.
function is set.
mode.
function is set.
mode.
function is set.
JohnnyCake
05-31-07 05:35 PM
