awd staggered wheels
sup fellas
i wanna know if i can do a stagger wheel set up on my 06 gs300 awd
i heard it will mess up the awd alignedment or somethin like? i don't know
but anyway's any info would be great
keep up the good work to all club lexus members
meaning the offsets can be different as long as the tire sides are the same.
for example, 20x8.5 front with an offset of 35 and 20x8.5 rear and an offset of 45. the tire size would be around 245/30-20 or even 245/35-20 but I would go with a 245/30 just because I hate chunky tires. Plus sometimes you get rubbing if the offsets are a little off.
You can do it, but I wouldn't recommend so unless you care more about looks rather than performance and practicality. To make a long story short, I've done enough research to feel confident that nothing should get damage running a staggered setup (if setup properly).
this is what i'm talking about
no offenced to all you guys that reply
i really appreciate all the info and feed back
but one person saying yes and another saying no and another saying yes but would not recomend it?
i read most of the other threads that you guys posted and i know you guys have had this same discussion before
i would like to do stagger 20" and drop the ride
if i did decide to do it
what would be the best set up
and thanks again for the help and info
nardeezy
GS300 AWD (black/ash)
Tanabe NF210 coil springs
20x8.5 & 20x10 iForged Aero wheels
245/35/20 & 285/30/20 Dunlop SP Sport 9000 tires (1st Set
245/35/20 & 275/30/20 Sumitomo HTR ZIII (Current Set
do you still have your same staggered setup and what issues do you have
exclusive matchup
say someone has 245/35 and 285/30, the difference front and rear on diameter is less than 1mm. are you telling me that will cause problems? that's kind of hard to believe isn't it, coz' two 245/35 can have deviation that big already
tell me more info so i can get a better understanding and help clear up the confusions
do you have more info? i know a lot of bmw and audi awd cars have staggered wheels and they never have problems on awd system messed up
this is NOT going to mess up the AWD system!
I would personally run a 19x8.5 rim in the front and a 19x10 rim in the rear. I did this on my IS....If I pick up the GS I will be doing the same on that. You can PM one of our vendors MrMark also. He has a 2IS, but he has staggered rims and has since he got the car with no issues
good luck on your wheel search!
