Need help with new RIMs
Would I have any rubbing issues if I keep the stock height of my car (for now) and installed 20x8.5F +25 and 20x10R +35? I think I would. I've been researching that the tires to go with would be 245/30/20 and 275/30/20 (though I know the rear would be slightly taller than the front).
I have this feeling that the +25 and +35 offset on a 8.5 and 10" wide wheel would really be aggressive (in a bad way) and probably require substantial rolling of the fenders.
Am I correct?
Am I correct?
Tires: Most people go with 245/35/20 and 275/30/20 or 245/30/20 and 275/25/20. The second set is closest size to your stock wheels/tires.
You might need to change those offsets. I'm pretty sure +25 is to aggressive. If you don't lower your car, I don't think you will have much rubbing issues unless your offsets are way off.
