automatic headlights not turning off
for anyone with this, trouble shooting should be super easy....leave windows down and look in to see if map lighst stay on or interior lighting stays on, if so, it is your door swicth, take it out using teh single screw and clean it spray it down, this will start to happen to the 06s first and many of those will be out of warranty for crap like this by now
always shut everything off...a/c, radio/cd player volume down to 7, windows rolled all the way up, mirrors in.
does anyone have a problem with the automatic headlights not turning off? it's very intermittent, so when i take it to the dealers they aren't able to replicate it. it's starting to be a more common occurrence, and causing my battery to die if i don't turn it off manually. any ideas or suggestions?
It is the door switch, you should remove it and check the connections inside, someone on here did and said that theirs was loose, and all it took was for them to tighten up the connections and it worked again.
If that fails, I think the part is only like 10 or 20 bucks at the dealer, get all 4 while you're at it so you don't have to deal with it again.
GL!
GL!
GL!
GL!
I have a older gs430. A 01, but this was happing to me and what I found was the truck had been popped open and I didn't see that. So remember if your truck is open the headlights won't go off till the truck is closed.
Jerbou71 (03-05-18)
Mine were doing the same... If I wiggle the switch, I can see the lights on the door pockets flash different from the interior... I am guessing I need to replace both sides.
I hear this is an easy one-screw, one wire swap... anyone do a quick writeup?
thanks!!
thanks!!
https://www.clublexus.com/forums/gs-...with-pics.html
