automatic headlights not turning off
Old 09-29-08, 06:01 PM
frebay
frebay's Avatar
Default automatic headlights not turning off
does anyone have a problem with the automatic headlights not turning off? it's very intermittent, so when i take it to the dealers they aren't able to replicate it. it's starting to be a more common occurrence, and causing my battery to die if i don't turn it off manually. any ideas or suggestions?
Old 09-29-08, 06:41 PM
Mesca
Mesca's Avatar
If you leave your headlights on automatic and you get out the car and lock it, it should turn off.
Old 09-29-08, 10:11 PM
Anthai
Anthai's Avatar
ya what's the difference when u leave your lights on automatic or not?
Old 10-01-08, 09:50 AM
socalJD
socalJD's Avatar
No problems w/my 08 GS350 - I leave the HL on auto all the time. When it's dark and I park and get out, the lights will go off in 30 seconds. If you open a door/trunk before the lights go off, it will re-start the 30 second delay.
Old 10-01-08, 09:54 AM
whlkev
whlkev's Avatar
I am 100% manual, i hate automatic crap I like to be in control
Old 10-01-08, 11:13 AM
slk_dds
slk_dds's Avatar
Yap, same here... I always turn off everything before I shut off the engine!!!
For Frebay: Use the remote to turn off the lights...
push lock once = lock
push lock again = turn off the lights
Old 10-02-08, 02:41 PM
frebay
frebay's Avatar
that's my problem... when it's set to automatic and i push the lock button the lights don't turn off. unfortunately the dealer can't replicate this.
Old 10-02-08, 02:52 PM
whlkev
whlkev's Avatar
it's not supposed to go off on its own until 30 seconds later
have you tried it at all?
1) wait 30 seconds to see if it goes off
2) press lock button TWICE to see if it goes off
Old 10-19-09, 11:06 PM
louman67
louman67's Avatar
Default Headlights not turning off.
I've started to experience the same thing. The HL will not turn off by themselves nor when I press the lock ob the key fob twice. I have to actually turn the switch to the off position. But it's intermittent and does not happen when I need to show it to the dealer.
Antone else out there with this problem?
Old 10-20-09, 04:22 AM
IXI187IXI
IXI187IXI's Avatar
ha same. i have a fear of coming out to a dead battery in the morning.
Old 10-20-09, 05:54 AM
CVGolfer
CVGolfer's Avatar
Frebay,
Every once in a while when I park my car in the garage for the night, the auto headlights stay on. For me, I think it is either the left or right front door switch that fools the car into thinking the doors are still open causing the lights on to stay on. The switches could be a little out of adjustment or one or both of them are simply going bad but since it has happened twice in 2.5 years, I just open and close the front doors to cure the problem. For my car anyway, it works every time.
Hope this helps.
Old 10-20-09, 08:24 AM
The G Man
The G Man's Avatar
The door switch would make sense. You can also have the dealer program it to shut off the headlight right away when the driver door is open.
Old 10-20-09, 08:40 AM
rominl
exclusive matchup
rominl's Avatar
even with the switch in on position, if engine is off for a while the light will still go off, at least on my car (forgot to turn it off one time)
Old 10-20-09, 09:20 AM
VIPNiSS
VIPNiSS's Avatar
I had the same problem and the dealer changed out a door sensor that tells the system your doors are closed and for the lights to turn off
Old 11-06-09, 12:23 PM
frebay
frebay's Avatar
dealers finally fixed my issue, had something to do w/ the door sensors.
Quick Reply: automatic headlights not turning off
