headlight - light bulb
Trouble Maker
Bulbs info
Low beam: D4S for oem bulbs or D4C for aftermarket
High beam: 9005 Halogen bulbs
Fog Lights: 9006 Halogen bulbs
If you want HID fogs.. you'll need to get a set of 9006 HID conversion kit.
Hope this info help
I remember when installing my HID fogs I needed to change the FOG LIGHT fuse to a higher amp. If you dont do that you'll be blowing the regular fuse for your fog lights every 2-3 seconds when you turn it on.
Hey everyone i had the same problem when changing my head lights too.
I'm changing my HID 4300K for 6000K HID and just like poorbong after 3 sec it will turn off. I made sure they were in the socket correctly and tryed it on both sides, got the same results. The link below are just like the bulbs i bought, after i put the upgraded bulbs they went out so i put the stock back in and they worked fine.
Eliminates the wiring and the bulbs, because they do work for 3 sec but than turn off. Donno where to go from here . . . .
http://cgi.ebay.com/ebaymotors/_Car-...=p4506.c0.m245
hmm i always wanted to post this up. I have this problem at Piranha has also. My headlights also go out randomly. i got my bulbs from xenondepot and i had them reinstalled like 3-4 times and i got them replaced by xenondepot 1 time. The thing is, the bulb isnt popped or anything, it just turns off after a while and i have to turn off the lights and turn it back on to get them on.
XinMinn
07-23-05 05:52 AM
