Which Tire Set-up Will Not Rub???
I Have An '06 Gs300 RWD. Which Of The Following Tire Set-ups Will Not Rub. I Am Going To Purchase Some Rims And Tires Tomorrow. Thanks.
245/35/20 (front) 255/35/20 (rear)
Or
245/40/19 (front) 285/35/19 (rear)
Or
personally, why would you go 19's when you could go 20's for a minimal cost difference?? the 245/35/20 is the same overall diameter of your factory 17's if that helps. the 255/35/20 is going to be a little bit larger than your factory overall diameter. probly about 1/2" - 3/4" difference.
I THINK I AM GOING WITH THE 19s. HERE IS THE SET-UP...JUST WANT TO ENSURE THEY WILL FIT. THE OFFSET IS 20. THANKS AGAIN GUYS...AND GALS...IF ANY.
FRONT
19X8JJ 245/40/19
REAR
19X9.5JJ 285/35/19
FRONT
19X8JJ 245/40/19
REAR
19X9.5JJ 285/35/19
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
i hope you dont plan on lowering that thing.......at all. the norm for offsets us usually about high 30's for the front and mid to high 40's for the rear. i think you should do your homework a little!
245/35/20 will rub...and doesn't matter on offset it'll still rub. It's because when you are lowered and roll with a 0.5" larger diameter on the tire, you are going to rub on the plastic liner (from experience). Go with the 245/30/20 tire up front, and rear use whatever you like. Unless you are going to run a 245/35/20 on a 10....the tire will rub
plug in your numbers here.
you will need to know the offset of the prospective rims for best calculations.
Your current offset (if stock rims, is 45).
steviej
steviej
neillexx
Wheels, Tires & Brakes Forum
04-12-06 08:20 PM
