06 GS 300 and 350 body styles
Old 10-15-08 | 10:34 AM
bryanc182's Avatar
bryanc182
Default 06 GS 300 and 350 body styles
Gotta random question...is there any difference in the body style of an 06 gs 300 and 06 gs 350? The reason i'm asking is it seems the 350's sit a little lower to the ground. Am i the only that sees it that way?? And can the rims on the 350 fit on a 300??
Old 10-15-08 | 10:36 AM
whlkev's Avatar
whlkev
CL Folding 25,000
probably because the 350 has bigger rims to mess with your perceptions
and yes, all rims are interchangeable.
Old 10-15-08 | 11:18 AM
socalJD's Avatar
socalJD
First, the GS300 debuted as a '06 model, and the GS350 replaced it as a '07+ model (you won't find a USDM 06 GS350). The only noticeable exterior difference is the GS350 has a sharkfin antenna, whereas the GS300 doesn't. The 350 motor is a lil' heavier, so that may add to the lower appearance.
Old 10-15-08 | 11:31 AM
whlkev's Avatar
whlkev
CL Folding 25,000
just checked for you, GS350 is 259lbs heavier than the GS300, probably due to engine/brakes set up
but the overall height dimension is exactly the same, so.. just an illusion.
Old 10-15-08 | 11:55 AM
07350FROST's Avatar
07350FROST
although one can get an '06 for a lot cheaper....i would recommend on getting an '07 if at all possible. the difference in power and braking is more than enough to convince anyone to spend a little more money.
besides, the '06 has more issues with rattles and crap!!
get a 350, you'll thank yourself.
Old 10-15-08 | 12:28 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
haha, not like 07 or 08 are much better on the rattles (at least on some cars)
but yes, i wouldn't consider 300 at all. doesn't make sense even with price factor imho
Old 10-15-08 | 12:31 PM
bryanc182's Avatar
bryanc182
Too late..i already got an 06! So far so good. Lets hope it stays that way! I appreciate the feedback fellas!
Old 10-15-08 | 12:44 PM
lexmaniac's Avatar
lexmaniac
the difference is the front and rear bumpers has been resigned also the front grill and the outside rear view mirror. that's all
Old 10-15-08 | 01:22 PM
whlkev's Avatar
whlkev
CL Folding 25,000
^^ that's only on the 08, i am sure he is comparing to a 07
phatz
07-22-09 01:55 PM
MyR6eatsme
06-14-09 02:11 PM
notsure
04-21-09 03:09 AM
GGenovese
02-27-08 05:45 PM
Atlantic84
03-02-07 09:40 PM
