09 GS now available
http://www.lexus.com/lexus-share/ima...ior/g_ext2.jpg
i think they really upgrade their foglight to LED with projector...
i know i can get that thing...
but hey! it's almost 2k for that stuff...
i'll be kinda mad if that's standard on new gs...
according to their spec.
they change foglight description to the following
Foglamps Integrated projector-beam foglamps
sigh.. i want that LED fog light too!!!
yo val you should hit D1 with the LEX. you are pretty bad *** in that luxury cruiser. I have to be honest I got a little crazy today and turned off the traction control today and pulled some pretty hard take offs and turns. The fact that the car has LSD is weak and is evident when you push it hard
exclusive matchup
they usually photoshop the background, not the actual car...
executive matchup
Nope, I don't think so. Before I picked up my 08 450h, I told my salesman that I wanted the 09 because it has a bigger trunk. He goes into his Lexus software and drills down on the specs for both the 08 and 09 GS 450h. Clear as night and day, both 08 & 09 had the same cargo capacity (forget the actual amount).
exclusive matchup
executive matchup
i'm telling you what i saw, henry! lexus canada software that the salesman used to show me the specs: the 08 and 09 has the same cargo capacity. if the 09 had a 40% bigger trunk, it would show on the 09 spec drill down. maybe canadian models don't get the bigger trunk? unless the program was faulty...i will go back to my salesman and get him to print off the spec sheet to confirm.
I noticed one difference on the 09 GS450h photos, (or maybe I just overlooked last three years). On the 09 Lexus photos, there are the rear fog lights used to be only available for the non-US market GS350, 430, & 460, etc.. However, I am not able to find it from the 09 spec, nor I remember I 've ever seen any 3GS on the road with it. Any GS450h owners can verify?
Lexus Connoisseur
Rear fog lights are usually aux. red lens lamps that emit light as bright as you are depressing your brake pedal. The taillamps on the 3GS are LED, but run on 2 different intensities instead of the conventional double filament bulb (regular on and full bright from brakes). Rear fog lamps usually means one or two of the rear taillamp lenses (either right or left side and body and or decklid mounted). Rear fogs on most new cars today are just relays to allow one of the taillights to run at full intensity at all times rather than half intensity when your lights are on.
